Help With Wiring! - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 10:34 AM   #1
Help with wiring!
Hi everyone, my name is Dave and I have a quick question concerning wiring. I have a few small computer fans that I want to hook together and use them in a project I'm working on. My question is what would be the safest and best way to power them? Do I just connect them all to one cord and plug it in? Any help is appreciated! Thanks!
smotpoker is offline   Reply With Quote
Old 10-26-2010, 11:00 AM   #2
Rewards Points: 252
Whats the voltage? Current? Hz? Of each fan?
The Following User Says Thank You to J. V. For This Useful Post:
smotpoker (10-26-2010)
Old 10-26-2010, 11:01 AM   #3
" Euro " electrician
frenchelectrican's Avatar
You will need DC power supply the size will depending on the total current draw on all the fans itself.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 10-26-2010, 11:16 AM   #4
The fans are 12V 14A
Old 10-26-2010, 11:45 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,990
Whoa. 14A? You sure that's not .14A?
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Old 10-26-2010, 12:02 PM   #6
Whoops, you're right, .14A
Old 10-26-2010, 12:09 PM   #7
the Musigician
DangerMouse's Avatar
What are you making? An old computer Power Supply would probably be best to power it with. How many fans?
DM
Old 10-26-2010, 12:13 PM   #8
I was hoping to be able to just wire them to a DC power adapter but I'm not entirely sure it's safe or if I would have to use 3 separate adapters, which I would like to avoid.
Old 10-26-2010, 01:38 PM   #9
the Musigician
Do you have a 12v DC adapter to try it with? It SHOULD work fine for 3 fans....
DM
Old 10-26-2010, 05:40 PM   #10
I=E/R
a7ecorsair's Avatar
You should be able to find a 12V 500ma adapter that should handle this.
a7ecorsair is offline   Reply With Quote
Old 10-26-2010, 11:35 PM   #11
dmxtothemax's Avatar
Rewards Points: 5,610
Even the smallest 12v plugpack would have no trouble running all three fans.
Use a standard plugpack 500ma will do nicely.
dmxtothemax is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
