HELP - Wiring A 4 Gang Switch Panel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 04:52 PM   #31
I thought everything worked... Then I discovered that when I turned the 3-way switches OFF from the 2nd level, the downstairs switch would not turn them back on.
Also found out that one of the terminals controls a bathroom light in my basement under the porch. After some study of online diagrams and my own, I think I've got it figured out. I think. I need to figure out which lines are Power and which lines go out to the lights...
So here's my plan - does it seem to make sense to anyone else?
I want to wire it so that my basement light always has power (there is a switch in the room itself), and I want to be able to have a switch on an outlet in the room (labeled R for Recepticle)
Tim_ is offline   Reply With Quote
Old 01-14-2010, 06:27 PM   #32
joed's Avatar
Rewards Points: 11,964
Now it makes sense except for one thing. I think you said the doorway light 3way was on a different circuit. If that is true you have a crossed neutral by connecting it with all the other neutrals.
If it's all on one circuit it makes perfect sense.
3-way switch wiring problem drewhart Electrical 12 12-14-2009 10:08 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 10:58 AM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 07:25 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
