Help Wiring In A 2.2kw Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 02:59 AM   #1
Help wiring in a 2.2kw compressor
Hi all,
I am about to install a 2.2kw Hydrovane air compressor in to my workshop. I propose putting in a separate electrical supply from the main house fuse box to the workshop.
The compressor runs at 11-16amps but spikes above that on start up, therefore I have been advised to use a 30 amp fuse/trip and 6mm cable?
I would also like to know what kind of trip switch unit I should fit in the workshop (all cable will be enclosed in trunking and underground between the house and the workshop).
I have 2 spare fuse/trip sockets on my house fuse board which I can install a 30amp trip (sorry, don't know what the technical term is for these). I then plan to run the 6mm cable from one of these to my workshop.
Any advice or steering would be appreciated.
Thanks, Stu
stuwindsurf is offline   Reply With Quote
Old 09-03-2010, 05:52 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
This first thing you need to do is tell us your location.
Old 09-03-2010, 09:05 AM   #3
Hi, sorry, I'm in the UK.
Old 09-03-2010, 10:36 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Ok what you should have slow blow fuse aka class c fuses or class C ciruit breakers they are sized to handle the start up surge of the motorus.
You may need RCD on this one { I am not 100 % on UK part but I know in France we have to do that on 240 volt circuits but not on 415 unless the local code required }
Merci.
Marc
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 12:46 PM
Wiring air compressor in to shop KAdams4458 Electrical 39 09-07-2009 04:13 AM
Air compressor wiring help integlikewhoa Electrical 3 01-18-2009 11:42 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Replacing Wiring From Outside Fuse Box To Central Ac Compressor bobo Electrical 8 03-02-2007 09:23 PM
