Help With Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 02:24 PM   #1
Tdsgraffiti's Avatar
Help with wiring
I have a pic attached of 3 wires in a box:
From left to right here is what I have,
First is Main power coming in
Second goes to a motion sensor light outside
Third goes to main light in shed, I also want to put a receptacle in. Can it be done?
Tdsgraffiti is offline   Reply With Quote
Old 02-17-2013, 02:35 PM   #2
Rewards Points: 14,306
Yes and no.
You can have a switch and an outlet like this.
http://www.bing.com/images/search?q=...electedIndex=3
But all outlets in a shed or garage have to be GFI protected so you would have to feed the outlet from a GFI.
Old 02-17-2013, 03:30 PM   #3
joed's Avatar
Rewards Points: 13,718
Sure you can.
Connect all the whites together and to the silver screw on the receptacle.
Connect the power black the shed black and two short 6 inch pigtails together. Connect one pigtail to the switch . Connect the other pigtail to the gold screw on the receptacle.
Connect the motion light black to the other connection on the switch.
Connect all the grounds to the box grounding screws and one of them also to the receptacle green screw.
Old 02-18-2013, 05:05 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Good luck. I don't think the box is big enough. Is that 12/2 romex? What size is the 2 gang? DId you run romex underground?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 02-19-2013, 09:44 AM   #5
ericmunyon12345's Avatar
Are there switches in this box or just splicing hots and neutrals? If a switch to the shed, then if the switch is off neither the outlet nor light would have power. If just splicing, then yea, but do as stated above and go to a gfci recep with "load" going to switch and light. Or even better, use a blank gfci (no switch or plug, it's just got the test/reset buttons), then you can use regular receptacles in the shed powered thru the load end.
ericmunyon12345 is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
