Help With Wiring: 1 Switch Controlling 2 Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 05:16 AM   #1
Help with wiring: 1 switch controlling 2 lights
Hello. I'm a new home owner and DIY-er. I have 3 fluorescent lights in my basement. I just replaced the fixtures' older ballasts with new T8 ballasts in the first two lights and they work fine. I am having trouble with the third light's wiring to the ceiling. I cut and removed the old ballast without paying much attention because I was able to wire the first two lights without any problem. I connected the new ballast to the bulb sockets in the fixture, just like I did with the first two lights. When I went to connect the ballast's black and white power lines to the ceiling lines, I was thrown off by a red wire, which I guess is connected to the light switch. In addition, this light is connected to the one of the other fluorescent lights and both are controlled by the switch. I have attached pictures of how I have it wired.
The way I have it wired now, the other light turns on and works fine when the switch is flipped. However, this light has the bulb flicker and then not turn on. If anyone can tell what I'm doing wrong from looking at the pictures, I'd appreciate any help! Thanks!
Help with wiring: 1 switch controlling 2 lights-1.jpg   Help with wiring: 1 switch controlling 2 lights-2.jpg
streko is offline   Reply With Quote
Old 05-02-2012, 08:30 AM   #2
Does anyone have any thoughts?
Old 05-02-2012, 09:20 AM   #3
joed's Avatar
Rewards Points: 13,344
Cap the red wire and try putting the ballast black with the other blacks.
If that doesn't work then open the switch and tell us the wires in the switch box.
Old 05-02-2012, 09:28 AM   #4
Rewards Points: 2,516
SO the lights are kind of "daisy chained" together from the switch? Check the connections at the 2nd light and make sure all connections for this 3rd light are secure.
Help with wiring: 1 switch controlling 2 lights-3-lites-daisy-chained.jpg
hammerlane is offline   Reply With Quote
Old 05-02-2012, 10:07 AM   #5
Rewards Points: 322
Nice pic, Hammer. Did you do that? Got any more?
puttster
puttster is offline   Reply With Quote
Old 05-02-2012, 12:35 PM   #6
puttster
Heres one from a previous post about a 4-way switch arrangement with 11 can lightst. Make them with Microsoft paint program.
Help with wiring: 1 switch controlling 2 lights-4-way-11-can-lites-2.jpg
Old 05-02-2012, 09:43 PM   #7
The ballasts are wired the same way? If its on but flickering or only has its ends lit it is probably a lamp/tombstone/ballast issue.
It seems more likely that the way you have it connected that it might not be doing anything at all. If this is the case try putting the wire from the ballast with the 2 blacks tied together instead of the red.
AltaSparky is offline   Reply With Quote
help wiring exhaust fan w 2 lights AND a separate shower light into a 4 switch Taran7 Electrical 2 09-18-2014 06:07 PM
4 way switch setup with multiple runs of lights CapeCod153 Electrical 23 03-28-2012 02:27 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
