Help With Wire Configuration - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 11:44 AM   #1
Help with wire configuration
Hello, I recently bought a house a few months back. I was in the process of starting to install a new light but came across what I think is a weird wire configuration for our foyer light. There are 2 3-way switches and 1 4-way switch. There is 14/3 wire coming into both 3-way switches. There are 2 14/2 cables coming into the 4-way switch. I thought the 14/3 should be coming into the 4-way switch and then back out to the second 3-way switch. I'm a little confused on this configuration. Could anyone be able to help me figure out how this is wired?
Thanks,
Jason
jaason2004 is offline   Reply With Quote
Old 05-27-2012, 12:32 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks,
Jason
Its not weird, a four way switch only requires 4 conductors. The real problem is that if you can't draw these wiring diagrams on paper, its hard to envision the endless wiring possibilities that are possible.
Old 05-28-2012, 07:36 AM   #3
Rewards Points: 1,588
Why are you fussing with the switches when the light connections are in the ceiling? Should be no need to rewire the switches to get the light to work.
bob22 is online now   Reply With Quote
Old 05-28-2012, 07:41 AM   #4
joed's Avatar
Rewards Points: 12,866
This is a bit unconventional but it can work if all the cables from the switches go back to the fixture box. It would need to be one large box to fit all the cables into it properly.
Old 05-28-2012, 01:07 PM   #5
Rewards Points: 2,516
Heres a diagram although it may not match your setup. Power coming into this setup via the 3-way switch on the right.
hammerlane is offline   Reply With Quote
Old 05-28-2012, 01:29 PM   #6
Licensed electrician
Rewards Points: 1,616
If you are replacing a switch make the new connections the same as the old. No need to mess with any connections not related to the fixture.
Old 05-28-2012, 02:38 PM   #7
E2 Electrician
Thats the problem, so many ways to to wire a 3way 4way setup.
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
