Old 11-21-2007, 01:33 PM   #1
Help with Well Pump Wiring....
Hi. I'm trying to hook my pump up to a new control box. I have a post with all the info going in the Plumbing forum, but I thought I'd bring you electricians into the discussion - you can never have too much brain power. Please follow this LINK, because I'm too lazy to type it all out again - haha. If you have ANY ideas, please post in either forum... I will check it hourly, because I'm desperate to have this fixed.
Thanks in advance
Fix-It Chick is offline   Reply With Quote
Old 11-21-2007, 02:42 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
See your post in plumbing.....your breakers are on the same leg you need to change that and use a double pole breaker instead of two single poles.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Sump Pump wiring Redline77 Electrical 2 09-25-2007 10:16 AM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 06:50 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 11:42 PM
stuck in well pump hell crossthreaded Plumbing 2 08-21-2006 05:32 PM
