Help With Wall Switch - Constant Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 07:50 PM   #1
Help with wall switch - Constant voltage
I'm trying to install a ceiling fixture light already existing wiring that's in the ceiling.
There are four wires total in the ceiling. White, Red, Black and a bare Copper ground. The Red and Black wires have constant voltage going to them even when I switch it off via the wall switch.
I took the wall switch apart and found that there's a Red and Black wire going to it and those also has constant voltage going to both wires even when I switch it off. I've already swapped the switch with a known working one and the same issue occurs, both Red and Black have constant voltage.
Anyone know what I should be doing to get this ceiling light fixture working properly? I can wire it up but it always stays on... I need it switchable from on and off.
Here are the pictures of the switch and the ceiling wires:
Any help would be greatly appreciated!
gambit023 is offline   Reply With Quote
Old 10-18-2011, 08:15 PM   #2
I=E/R
a7ecorsair's Avatar
What was connected at the ceiling box before you started this project?
a7ecorsair is offline   Reply With Quote
Old 10-18-2011, 08:49 PM   #3
I believe it was a ceiling fan. Not 100% sure though.
Old 10-18-2011, 09:11 PM   #4
you have something mixed up here. Your picture with the switches states two red and black wire. Is that right? Looking at your picture of the ceiling I see a red, black, white and green ( ground) Please clarify what is at the switches
Tom Gramc is offline   Reply With Quote
Old 10-18-2011, 09:20 PM   #5
jburd964's Avatar
Rewards Points: 166
Do you have two are three way switches on circuit ??? Are unidentified switches in room?
I'm not a professiona., But I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 10-18-2011, 09:30 PM   #6
jburd964's Avatar
Rewards Points: 166
Looks like you needs to pull the switches out of box disconnect all wire and check continuity of wires/ trace their paths.
I'm not a professional., But I did stay at Holiday Inn Express last night.
Old 10-18-2011, 09:30 PM   #7
joed's Avatar
Rewards Points: 12,908
How did you determine that the wires are always hot? If you used a digital meter it could be a false reading known as phantom voltage.
What happens if you connect a light to the red and white at the ceiling and flip the switch?
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
What wall switch for bath fan/light/heater? janralix HVAC 8 07-20-2009 04:07 PM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 08:13 AM
Wall Switch sue Electrical 4 02-06-2005 07:05 PM
