Help, Wall Light Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2008, 04:38 AM   #1
help, wall light problems
Hiya, I recently decorated and to do so had to take wall lights off. Since putting them back, one of them isnt working. Ive checked wiring, bulbs and even swapped wall fittings over to see if it was faulty, but its not. There is power getting to the one that wont work, so why wont it work??? Please help cos its driving me crackers!!!
joosey_loosey@yahoo.com is offline   Reply With Quote
Old 11-09-2008, 04:52 AM   #2
Rewards Points: 1,192
Have an electrician check your splices.
bobelectric is offline   Reply With Quote
Old 11-09-2008, 05:50 AM   #3
Whatamess
How much power are you reading at the light that does not work?
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 11-09-2008, 10:18 AM   #4
joed's Avatar
Rewards Points: 11,966
Tell us how you checked for power. Problem could be a loose connection at one of the working fixtures or switch.
Old 11-10-2008, 08:38 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Are you in the UK? If so, did you use a test meter to check for 240V, hot (live) to neutral at the fixture point? How do you know you have power at the fixture (fitting)? Sounds like a loose/bad connection somewhere.
Kyle
Used T&G OSB as sheathing on a 22' wall, problems ? iMisspell Building & Construction 3 10-15-2008 11:49 PM
Has anybody had problems with those basement light fixtures? rgsgww Electrical 1 09-05-2008 01:29 PM
replacing wall mounted light fixture donnakay78 Electrical 3 06-12-2008 09:07 AM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
