Help W/ Voltage Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2009, 07:06 PM   #1
Rewards Points: 274
help w/ voltage meter
I am trying to find out why a light isn't working (either switch or fixture) Where do I touch red prong, black prong on my voltage meter? Black wire, white, ground?? Thanks
ugabulldog is offline   Reply With Quote
Old 04-29-2009, 07:15 PM   #2
Bigplanz's Avatar
Rewards Points: 948
Touch one probe on the black and one on the white. If there is voltage, the meter will show it. The black is hot, and the white is the 'neutral.' A current should register if you touch a probe to the black and one to the ground, but that just means the circuit is properly grounded. The ground wire is NEVER supposed to carry current except when there is a short somewhere, then the current flowing through the ground trips the breaker.
Bigplanz is offline   Reply With Quote
Old 04-29-2009, 08:28 PM   #3
Depending on what kind of meter you have, you may see
http://en.wikipedia.org/wiki/Phantom_voltage
Old 04-29-2009, 08:50 PM   #4
Rewards Points: 1,442
For household power voltage measurements set the meter to at least 240 volts AC. (If you are sure you will be testing only 120 volt circuits then set the meter to at least 120 volts AC)
It does not matter which terminal or location you touch the red probe to.
AllanJ is online now   Reply With Quote
Old 04-29-2009, 09:46 PM   #5
Rewards Points: 274
thanks for the replies, however I am still confused..... touch black probe to the ??? wire, and red probe to the ??? wire. (I know black wire is hot, green/bare is ground and white is neutral)
Old 04-29-2009, 09:55 PM   #6
Tired & Dirty
Rewards Points: 83
Black probe to neutral or ground, red probe to hot (black or red hopefully) wire. White is usually neutral but on a switch it could be the switch leg to lite fixture.
evapman is offline   Reply With Quote
Old 04-30-2009, 12:06 AM   #7
Rewards Points: 506
Send a message via AIM to theatretch85
It doesn't matter which probe you touch to which wire. Pick a color any color, it will work just the same. The little Neon inside your tester won't know the difference. Its just like a light bulb, it can be wired backwards and it will still work.
theatretch85 is offline   Reply With Quote
Old 04-30-2009, 10:44 AM   #8
The critical thing to remember is that a multimeter measures voltage potential between the two probes when reading voltage. This means that it reads the voltage difference between the two probes.
You gotta remember this, because if you touch both probes to wires that happen to be both hot and on the same phase, your meter will read very little or nothing, when you actually have 120V present. Again, it reads this because it is reading the voltage difference between the two probes.
For example, if you put your meter leads on the two terminals of a light switch that has power and is turned ON, your meter will show near or at 0 volts, but you have 120V present on both terminals.
Willis
williswires is offline   Reply With Quote
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 10:54 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 07:35 AM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
