Help W/ Temp. Power Pole - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 09:02 AM   #1
Rewards Points: 274
help w/ temp. power pole
I am using this temp. power pole to build a house and also to hook up a camper that I will be staying in, and a well pump. It already has a 30 amp breaker and outlet for the camper, and a 2-20 breaker for the well pump. My plan is to extend conduit from bottom of camper outlet box down and run wires thru box down to 2 or 3 sets of gfi outlets?? (1 for well pump on 2-20 breaker, and 1 or 2 sets ?? for construction), their is only room for one more breaker in breaker box, what amp breaker should I use, and am I on the right track with everything else??? Thanks... (nevermind the conduit to right of breaker box, that will be eliminated)
help w/ temp. power pole-temp-power.jpg
ugabulldog is offline   Reply With Quote
Old 04-17-2010, 11:39 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
You can only add 1 receptacle and it can't be larger than 20 amp if using for general purpose gfci receptacles.
jbfan is online now   Reply With Quote
Old 04-17-2010, 12:15 PM   #3
Rewards Points: 1,016
Not sure I understand - the well pump already has a 220 volt connection, right? So why any change there?
As for the 120 volts outlets, you have just the one available breaker space - will this box take tandem breakers to you can get two breakers in that empty space to give you two construction circuits?
Old 04-17-2010, 03:41 PM   #4
Rewards Points: 274
1 receptacle meaning two places to plug into?
Old 04-17-2010, 03:43 PM   #5
Rewards Points: 274
No change on the 220, not sure about the tandom breakers...I can look into. Could I also, just swith the part the breakers go into for one that has more space?
Old 04-17-2010, 05:19 PM   #6
jbfan's Avatar
Rewards Points: 144
You can have as many receptacles on the circuit as you want, it just needs to be limited to nothing higher than a 20 amp breaker.
What brand of panel do you have?
Old 04-17-2010, 06:17 PM   #7
What is the feed to the Temp power pole ? 60a ...100a ??
Why not add a 60a 240v breaker & a small breaker panel
Then run circuits from that
Old 04-17-2010, 06:26 PM   #8
Master Electrician
Rewards Points: 3,684
It's probably coming directly off the meter and does not need a main if there are six or fewer breakers.
brric is online now   Reply With Quote
Old 04-17-2010, 07:27 PM   #9
Rewards Points: 274
Correct,...off meter
Old 04-17-2010, 07:54 PM   #10
Right, doesn't need a main...fine...sorta knew that - 6 throws
But if you need more circuits & its a 100a feed (or even 60a 240v) doesn't a small panel make sense ?
Directly off the main woyukdl have the 30a 240v pump
Then the other side a 60a 240v feeding a small sub
Only 2 breakers - shuts eveyrthing off
The sub powers the 30a camper feed + other circuits
Old 04-17-2010, 08:35 PM   #11
Master Electrician
Seems like overkill and added expense to me unless you're building a major highrise. Add a cicuit breaker for an additional 20 amp feed and plug an extension cord into the trailer for another circuit. Those two should accomodate an average home construction site easily.
Old 04-17-2010, 08:43 PM   #12
Rewards Points: 274
thanks
Old 04-17-2010, 10:25 PM   #13
That was my thought of adding a tandem breaker if possible, to get two construction circuits. If not, running one off the trailer is a good way to go too unless running a A/C unit in the trailer at the same time.
Old 04-18-2010, 09:15 AM   #14
Rewards Points: 274
I will look into tandem, two is better than one for ex.... framing w/ air compressor, saws etc.. thanks again
Can I give 12V DC to power inverter through PC Power supply? inverter General DIY Discussions 3 07-06-2009 10:38 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
temp power pole ?? ugabulldog Electrical 3 11-08-2007 10:42 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
