Help! Two Outlets Died At The Same Time. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2010, 03:47 PM   #1
Help! Two outlets died at the same time.
Two outlets died at the exact same time, but others on the same circuit did not.
I had lights plugged into both of the outlets in my garage and when I clicked the button for the garage door, after slightly less than a second, the outlets died, but the garage door continued to work. I've flipped all of the breakers, off and on, although none were tripped. I've tried different devices on each outlet, and neither work. Neither have any buttons on the front indicating that they had built in surge protectors. I've check for loose wires, but there are none.
Any ideas?
MindOfVacuity is offline   Reply With Quote
Old 06-19-2010, 04:45 PM   #2
>The ones that died are downstream of the others.
The outlets are on a GFCI downstream of the garage door power tap.
or
It was a coincidence that a wirenut downstream of the door power tap failed at the same time you opened the door.
or
Old 06-19-2010, 04:46 PM   #3
Licensed electrician
Rewards Points: 1,284
The receptacles with the buttons are ground fault protectors, not surge suppression.
I would look for a tripped GFI in the basement, outside or possibly the bathroom. Often times they have gotten hidden by furniture or stuff stored in front of them.
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 02:08 PM
downstream of GFCI outlets amakarevic Electrical 11 12-25-2008 02:13 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-09-2008 12:09 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 10:31 AM
