Help... Trying To Install Can Lights On The First Floor Of A Two Story House... - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2008, 06:44 PM   #1
Electrician
Question
Help... Trying to install can lights on the first floor of a two story house...
Just curious if anyone out there has attempted this before and if they have any good tips for me... I am an electrician my self and have considered cutting a channel down the center of the room in the ceiling and then using a 4ft flexible drill bit to drill out the the locations for the new can lights... any one else have any better ideas?? Please let me know..
I can also help to answer any electricial questions anyone else has as well..
Thanks,
John
whutitdew25 is offline   Reply With Quote
Old 03-15-2008, 07:17 PM   #2
Depends on the framing. You might get lucky and have trusses.
We don't bother with long bits anymore. Just cut and patch. It's only drywall. The long bits DO work but be careful. It's real easy to grab something you didn't expect like the carpet upstairs.....so I've heard
The last one I did had joists every TWELVE inches! That was a lot of cuts.
220/221 is offline   Reply With Quote
Old 03-15-2008, 08:02 PM   #3
electrical contractor
Rewards Points: 150
twelve inch framing! Ever try to crawl in an attic with a 4/12 roof and 12 inch framing? Not alot of room to move. On the bright side it is hard to fall thru.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 03-15-2008, 08:14 PM   #4
Electrician
yea I probably will just cut and patch the drywall... It'll probably be easier and faster in the long run... I plan on scraping the popcorn off the ceilings and going with a knockdown anyways.. Thanks
Old 03-15-2008, 08:47 PM   #5
Well, there ya go!
I love it when the customer scrapes/textures/paints and THEN calls us for cans.
Old 03-17-2008, 01:51 AM   #6
I use the long drill extensions without cutting channels. You do have to be careful. I had to repair a huge mess one time when an electrician used one of those bits and found a copper water line....and then had trouble locating the water shut-off.....disaster. I have yet to go through the upstairs floor or damage anything inside a ceiling, but I have only done it about 6 times with the long extensions. I actually have linked 2 extensions together a few times which gives me about a 9' long drill bit.
send_it_all is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 01:55 PM
My new beautiful house is falling apart!!! DonnaS Building & Construction 6 05-06-2006 04:30 PM
