Help Trying To Identify Main Panel Circuit Breaker Interlock Solution - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 07:35 AM   #1
Help trying to identify Main Panel circuit breaker Interlock solution
Hello,
I have a crouse hinds LC230PC -- 77030-05 circuit panel that has this odd looking shaped main 200A circuit breaker. I am trying to figure out the best option to tie into the panel a manual interlock solution for generator hook-up.
My first option would be to simply add a manual switch box between the meter and the panel outside my house. This would have a three position switch state. Either OFF, switch in the line from the Grid, or generator.
My second option would be to purchase a siemans manual interlock switch and have it installed by an electrician. This would allow me to safely turn off the main and switch a two pole (tandem) breaker connected to the generator outside. One question I have about my second solution, I have this hump style breaker, but cannot find the correct interlock switch for it. I have attached the picture in case someone can identify and point me to the location on the net for the siemans interlock solution. Please note, I am only looking for a siemans interlock solution, not an after market piece.
If any one has any additional ideas, please post them.
Thanks in advance.
Help trying to identify Main Panel circuit breaker Interlock solution-200a_hump_breaker.jpg
Linos is offline   Reply With Quote
Old 05-16-2012, 07:55 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Is the generator going to be sized to run the whole house?
I think you would need to purchase a transfer switch. The interlocks I have used and seen, won't be able to do what you are trying to do, unless the generator will be sized to power a smaller subpanel.
Old 05-16-2012, 08:24 AM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What is the model number of your panel. I think saw some online at one time.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-16-2012, 08:25 AM   #4
Code05's Avatar
Rewards Points: 1,104
Are you saying I cannot use a small portable generator and an interlock kit to power a main house panel?
Code05 is offline   Reply With Quote
Old 05-16-2012, 08:36 AM   #5
k_buz,
I would like to be able to switch in whatever circuit I need at the point in time. Do not want to corner myself with a 6 circuit or 10 circuit transfer switch.
So, I was looking these generators: http://www.generatorsales.com/order/...sp?page=H04595
what do you think?
thanks again.
Old 05-16-2012, 09:09 AM   #6
Code05's Avatar
Originally Posted by Linos View Post
k_buz,
what do you think?
thanks again.
An interlock kit is perfectly legal. The NEC allows manual load shedding for this application.
Nice generator.
Old 05-16-2012, 02:45 PM   #7
Sparky
Rewards Points: 510
You're not gonna find an off the shelf interlock for that old style breaker
interlockkit.com may be able to make you a custom interlock
Edit: Nevermind, interlockkit does make the correct interlock for that breaker
http://www.interlockkit.com/croushndsmain01.htm
Techy is offline   Reply With Quote
Old 05-16-2012, 03:31 PM   #8
thank you to everyone's response. I decided to send an email to siemens electric (who took over the murray company, who also took over the course hinds panel business) and here is the response:
The main breaker type in this panel was an MD-H. We do not have an interlock kit for this old style main.
I also asked how many tandem breakers is can accept and here was thier response. It can accept 10 tandem breakers.
I hope this will help other seekers.
Old 05-16-2012, 03:40 PM   #9
Master Electrician
Does that interlock kit come with a method of switching the neutral too or do you guys south of the border not need to do that?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-16-2012, 04:00 PM   #10
Sparky
Rewards Points: 510
We don't switch the neutrals in most cases
replacing main breaker vs. sub panel gf1025 Electrical 14 07-21-2011 01:38 PM
Which generator Interlock setup should I use for my sub panel? homerb Electrical 2 05-10-2010 03:44 PM
Sub-panel selewis Electrical 23 02-21-2010 10:52 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 12:52 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
