Help With Tracing Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2007, 09:06 AM   #1
Help with tracing wires
I have a few random boxes in my walls, switches that do nothing, dead receptacles and a ceiling fan without a switch (or it's dead).
I'm guessing the former owners were doing some wiring and decided not to fill us in. Attempts to contact them have failed, so I need a little help tracing these wires. I have a tracer that (is supposed to) traces the plug, light or wires to the breaker box. But is works about 20% of the time.
Any ideas?
Thanks!
mikey1377 is offline   Reply With Quote
Old 09-13-2007, 04:10 PM   #2
Rewards Points: 78
Tracers only work if the wiring is installed and powered up. Tracers do not locate open circuits and missing wiring.
I hate to tell you that you are going to have to open up all the switch boxes and receptacles and physically locate the disconnected or missing wiring.
You may also need to get access to the conductors at the panel and see where they are going and if they are connected properly.
You may need a professional for this project.
Old 09-14-2007, 09:11 AM   #3
If your not experienced in circuitry, don't even bother trying to fix it. You'll only cause yourself more troubles.
An experienced electrician will be able to examine the wiring in the boxes and know exactly where the wiring problem is
buffalonymann is offline   Reply With Quote
Old 09-22-2007, 11:41 PM   #4
Contractor in PA
If your home is in a development, check with a neighbor and see if their switch are in the same location and work the same items.
That may give you an insight as to how the outlets and switches are wired. You did not mention how old the home is or the type of wiring that is installed ( knob & tube, romex, bx etc). If the home is old with knob and tube, don't even try to do it yourself, because this type of troubleshooting is hard enough for the experienced electrician, so for a homeowner or handy man, it might be a long rough project.
michaelpwalton1 is offline   Reply With Quote
Old 09-23-2007, 01:19 AM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Mike your going through and posting on threads that have had no response in a month or so....are sure you want to do this?
Stubbie
Old 09-23-2007, 07:36 AM   #6
Contractor in PA
Hi Stubbie - To tell the truth, I was not watching the posting dates as close as I should have. I was looking more at the number of responses a posting had received and thought that I could help someone who was stuck on a project. I guess I should look a little closer. Oh well, it was good practice
Regards
working with hard to bend wires? darsunt Electrical 3 09-03-2007 09:39 PM
price for hooking up panel wires apeman76 Electrical 7 08-14-2007 03:04 AM
Running wires mt232 Electrical 4 03-22-2007 09:02 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Short Wires sensen Electrical 3 04-01-2005 01:36 PM
