Help! Three Way Switch Conundrum. (Diagram) - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 08:22 PM   #1
M@T
Unhappy
Help! Three way switch conundrum. (Diagram)
I'm not an electrician, but I get around ok.
This one has me stumped. I put in new switches in the box's and replaced the wiring except for the exterior wall because they are embedded inside a brick wall. I decided just to junction the old to the new wires. I wired the new switches just like the old ones, but up at the junction box I totally lost my way.
I need someone to solve the question mark on the drawing by connecting the lines and fixing anything else I may have screwed up.
It worked fine before, so I know this switch setup is possible...
M@T is offline   Reply With Quote
Old 09-11-2010, 08:26 PM   #2
M@T
Larger image here:
Couldn't get the larger image link to work
Old 09-11-2010, 08:44 PM   #3
steveel's Avatar
seems like you could dispense with the new source cable in the lower left if you wire the cans as "at end of run". That is, red-traveller to red-traveller and black-traveller to black-traveller between the 3-ways. The black common on lower RIGHT left connects to source. the black common on lower LEFT connects to the cans.
I think. I'm not an electrician. Did you do more than your code allows? If so, suggest getting legal.
SteveEl
PS Oop
steveel is offline   Reply With Quote
Old 09-11-2010, 08:45 PM   #4
steveel's Avatar
oh yeah, porch light switch just passes to porch light and ignores the other stuff.
Old 09-12-2010, 03:28 AM   #5
" Euro " electrician
frenchelectrican's Avatar
In the old switch box you have cable or in conduit { pipe } ?
If latter it will be much easier to deal with it.
Once I know the answer then myself or other members can able address the correct way to hook up the circuits.
Merci.
Marc
Tags
3 way switch , 3way , three way switch
In-Line Switch on Hard Wired Fixture 1sthome1068 Electrical 2 08-29-2010 07:42 AM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
