Old 02-05-2013, 02:32 PM   #1
help with thermostat
Thanks in advance for reading.
I'm fairly handy but don't have a lot of electrical knowledge - enough to replace switches, lights, etc, and enough to know to turn off power and not touch live wires. But not much more.
I have a wall mounted electric heater in my bedroom. The only thermostat is the one built into the unit. I'm not sure what happened to it, but if you turn it on to any number (1 - 10) it goes on, but then will just stay on continuously. So I imagine I need to find out if 120 or 240, but is there a replacement I can put into the unit where the existing one is or do I have to buy a wall mounted one and then connect it from the baseboard up to somewhere in the wall (not sure exactly how to do that - I've never run anything up through a wall, but I'm sure with some direction I could). For those that want to tell me to hire someone, its not going to happen, so good advice is greatly appreciated!
Cold in Boston
lrubin28 is offline   Reply With Quote
Old 02-05-2013, 03:13 PM   #2
MarginallyQualified
enough to replace switches, lights, etc, and...
...is there a replacement I can put into the unit
Of course. Start with the appliance parts stores near you.
Old 02-05-2013, 04:47 PM   #3
Time for a new heating unit.
bobelectric is offline   Reply With Quote
Old 02-05-2013, 04:55 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Cold in Boston
Make and brand of baseboard heater ... should be a data nameplate on it somewhere. Use this to look up a replacement thermostat. It could also be a heating element problem or voltage problem. Not going to tell you to hire anyone as purchasing an entire new heater would be more cost effective. A wall mounted thermostat would be fine also.
Thermostat Replacement kgreen4me Electrical 2 01-27-2013 12:46 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
