Help With Tapped Sub Panel. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 09:19 PM   #1
ericmunyon12345's Avatar
Help with tapped sub panel.
I want to pull (split bolts?) from the far left panel. I want to add a two space outdoor panel. I only need one 20 amp breaker for a recep and a 75 watt flood light. Tips on doing this would be great. I think I should tap the line side of that 100 amp box (b/c the load wires are so large for voltage drop...someone actually snipped several of the strands to fit it in the breaker terminal). I plan to use #6 cu thhn/thwn. The line side of that box is still load side of service drop (fed by large box with lever switch / lockout).
In the new two space, the neutral bus stays isolated, right? So, should I just attach the egc from the new plug and light to the box? The new box will be bonded to the 100 amp box via the nipple.
Help with tapped sub panel.-image-468899767.jpg   Help with tapped sub panel.-image-3356157027.jpg   Help with tapped sub panel.-image-1581036637.jpg   Help with tapped sub panel.-image-1207116215.jpg
ericmunyon12345 is offline   Reply With Quote
Old 07-04-2013, 10:11 PM   #2
Licensed electrician
Rewards Points: 1,290
Those terminals are for one conductor only. You cannot tap there.
Old 07-04-2013, 10:28 PM   #3
Right, but COULD I join to wires with split bolts? (This will not be inspected.). From the sub panel, I would run individual
Conductors in liquid tight transitioning to PVC.
Old 07-05-2013, 04:15 AM   #4
Electrician
Rewards Points: 150
You already have burnt insulation and damaged conductors above those line side lugs. And unsafe hack work on the load side. So, let's concentrate on doing this right. For property resale value, for insurability and, dare I say it, for safety.
If the wire from meter to main was rated for 420+ amps and the wire to the 100A breaker was rated for 120+ amps(it isn't), then we could bother to do a fill calculation. Otherwise split bolts and the tap rules are used on the load side of breakers.
In either case you need a new panel with at least four breaker spaces. Two spaces for a back fed breaker with a hold down clamp and two for the load.
The only way to use that new two space panel is to replace the 100A breaker with a quad. Unfortunately, the largest quad is 50A. Since that circuit is already burning up, 50A is definitely not going to make it.
Glennsparky is offline   Reply With Quote
The Following User Says Thank You to Glennsparky For This Useful Post:
ericmunyon12345 (07-05-2013)
Old 07-05-2013, 05:47 AM   #5
Electrician
Rewards Points: 150
I think your best bet is to replace that disconnect with a panel. There are a couple of ways to do it. You'll need to do some pricing and research.
You're also going to need to change those line wires from the main disconnect.
You have two choices for panels. An outdoor 100A main breaker panel with feed through lugs.
Or a Main Lug Panel with at least a 100A stab rating on the busses. Get a regular 100A breaker and a hold down kit. Back feed that breaker and use the main lugs for those aluminum feed wires.
Sorry, this is a much bigger job than you bargained for.
Old 07-05-2013, 06:46 AM   #6
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
This is your best bet, with what your trying to do.
Also, you couldn't "tap" that with #6's anyway.
Just because this isn't inspected doesn't mean you shouldn't do it right.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
k_buz (07-05-2013)
Old 07-05-2013, 08:05 AM   #7
Agreed! I only stated that because sometimes something perfectly safe and functional still isn't code. I may call someone in if there are problems with existing. Thanks.
Old 07-05-2013, 08:22 AM   #8
Rewards Points: 510
I'll agree with that somewhat.
I feel the NEC is starting to change for "customer convenience" and to make things "idiot proof" rather than what's safe/unsafe.
Unfortunately, some of the representatives on the code making committees, have their interest in mind rather than what's safe and practical.
However, people have mandated that, this is what they want by the way they vote. It isn't "change" it's dollars
Old 07-05-2013, 11:09 AM   #9
So is there general agreement that I should not tap from here? If so, I'll look at trenching from a load center...sounds like it might be less involved.
Old 07-05-2013, 01:39 PM   #10
Rewards Points: 510
Not saying that.
Replace the disconnect with one of these.
Take your 100 amp breaker and install it in this panel with a hold down kit.
Then, the wires that are connected to the load side of your breaker now, will then hook to the lugs on the new panel, THEN you will have space for 2 single pole breakers or tandems or whatever.
The wires from your main will hook to your 100 amp breaker therefore, you'll be backfeeding the new panel.
Old 07-05-2013, 02:14 PM   #11
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I dont see how the transfer switch is legal not being service rated and all.....
Old 07-05-2013, 03:27 PM   #12
Help me out. Transfer switch=the lever switch that is the main shutoff? Or the 100 amp switch I wanted to pull from?
Old 07-05-2013, 03:36 PM   #13
Rewards Points: 510
It is, it has a center "off" position.
Old 07-05-2013, 03:38 PM   #14
E2 Electrician
and? is it service rated? Where is the OCPD before the transfer switch?
Old 07-05-2013, 03:46 PM   #15
Rewards Points: 510
The difference in service rated and non-service rated is the center off position.
These switches don't have any OCP but have the center off position and are listed for use as service equipment.
I just got in a disagreement on another forum because I would think it needs some sort of OCP. Just isn't always what I think...lol
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
