Help With Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 08:19 AM   #1
Help with switch wiring
The switch pictured on the left powers bath fan and works perfectly. I just installed a vanity light yesterday to run off the switch on the right. The light comes on great but it doesn't shut off. Any help with this issue would be much appreciated.
jnlson is offline   Reply With Quote
Old 04-25-2012, 08:22 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
From the picture, it looks like you have two hot pigtails going to the switch on the right. That would indicate you have the switch leg tied in with the hots.
Even if I'm wrong and you only have one hot pigtail to the switch, I would still assume that you have the switch for the vanity light tied in with the hots.
The Following User Says Thank You to k_buz For This Useful Post:
jnlson (04-25-2012)
Old 04-25-2012, 08:51 AM   #3
I think you are right now that I look at it closer. I just pulled it out this morning before work and didn't notice that. So if I remove one of those pigtails, what other wire should go in there. Maybe you can't tell from the picture. Thanks.
Old 04-25-2012, 08:59 AM   #4
k_buz's Avatar
No way to tell you from the picture. You would have to figure out which cable goes to the vanity light, take that black out of the splice and connect it to the switch.
jnlson (04-25-2012)
Old 04-25-2012, 09:05 AM   #5
Rewards Points: 2,512
take the bundle of wires with the white wire nut and bend it down to take another photo
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
jnlson (04-25-2012)
Old 04-25-2012, 09:12 AM   #6
diagram does not show grounds for ease of drawing
Old 04-25-2012, 09:51 AM   #7
awesome diagram, thank you very much
Old 04-25-2012, 09:57 AM   #8
Think I got it, thanks everyone. Awesome forum.
Old 04-25-2012, 09:59 AM   #9
Code05's Avatar
Rewards Points: 1,104
Nice job, but your wire nuts need to be tan or red, yellows are too small for 3 #14s.
Code05 is offline   Reply With Quote
Old 04-25-2012, 10:08 AM   #10
Licensed electrician
Rewards Points: 1,038
Also the clamps in the back of the box are for one cable only.
jnlson (04-25-2012)
Old 04-25-2012, 10:17 AM   #11
Code05's Avatar
Good catch.
The Following User Says Thank You to Code05 For This Useful Post:
jnlson (04-25-2012)
Old 04-25-2012, 10:21 AM   #12
good info!
Old 04-25-2012, 10:54 AM   #13
k_buz's Avatar
The grounds to the switches are wrapped the wrong direction.
Ravenworks (04-25-2012)
Old 04-25-2012, 11:23 AM   #14
Code05's Avatar
Tough crowd today.
Now is the gap at the top left corner of the box more than 1/8"?
Old 04-25-2012, 12:09 PM   #15
Do we have at least 6" of free conductor on the cables that have been added?
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
