Help With Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 01:07 PM   #1
help with switch
in a box I have three wires, one hot wire coming from panel, one going out to under cabinet light, one going out to switch that with activate under cab lights, inside the box will be a GFI, how do I wire this?
thanks
honorea is offline   Reply With Quote
Old 03-27-2010, 01:31 PM   #2
Master Electrician
Rewards Points: 3,824
If I understand correctly, you have three cables in a switch box. One power cable, one to the UC fixture, and one to another switch box for a switch to control the UC fixture. If this is what you have then you need the power cable at the GFCI box, one cable from the GFCI box to the switch box for the UC switch, and a cable from the UC switch box to the UC fixture thus giving you two cables in each box. Yes, no?
brric is online now   Reply With Quote
Old 03-27-2010, 01:57 PM   #3
I have three wires in a single gang GFI recepticle box, the under cab lights are across the room and already wired, I suppose I could make it a duplex and add a switch, but I prefer the switch on the other end of kitchen, I need help on what to pigtail and a white wire is mabye hot or something?
thanks
Old 03-27-2010, 02:12 PM   #4
Electrician
Rewards Points: 792
Is this a kitchen counter plug, if so you arn't suppose to share that circuit with anything else.
But if you were going to do it, your white from your feed goes to the GFI and the UC light. The black from your feed goes to the GFCI and onto the white of the wire to the switch. The black from your switch goes to the black of your UC light.
darren is offline   Reply With Quote
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
