Help/Suggestions Running Cat5e Acroos Room To New Panel
Yes it is, especially if you do not have the length needed to pull into the room that you want. That is why you usually find the patch panels in basements by the Electrical panel, or utility closet. In businesses, they have been located in a closet that can be secured, that usually contains the telephone equipment.
If the basement is finished, you are SOL. If not, but can repull the wiring from the main floor if only one level, then do so. Now, of course, you can hide the networking equipment in a enclosure that has smoked glass, or in a Leviton Panel. Post a picture of the space where the panel is. One shot showing the stairwell with the panel, and then the room in question that you want to relocate to.
