Help With Sub-panel Installation! - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2009, 09:37 AM   #1
Help with sub-panel installation!
Hi all. I am finishing a basement room in my house. The house has a 200 amp main service, with one existing sub panel next to it.
The builder left me an unused 10-3 w/ground wire from the basement to the main service panel in the adjacent garage. I want to use this wire to feed a sub panel in the basement.[ I do not want to run additional wire to the main panel as the garage walls and ceiling are finished and I don't want to fish/feed wires through that.
Can someone walk me through this?
This is what I think I can do: Use a 30 amp 2 pole breaker in the main service panel to feed the subpanel..with no main at the sub-panel. From there, I want to run one 20 amp [work bench] and 2 15 amp circuits [one general purpose and one dedicated to a treadmill] ....so I assume the 20 amp on one side and 2 15 one the other and I am done......yes, and is this code compliant?
Do I need to go gfci?
Can someone confirm this and walk me through the subpanel hookup to the main box...I would hate to mess this up!
Oxymoron is offline   Reply With Quote
Old 11-29-2009, 10:17 AM   #2
2 hots to 30a breaker in panel, white neutral & ground to buss bars
These are usually the same bus bar unless you have a main shut off outside the house
Sub-panel - neutral must not be bonded to ground bar or case
Neutral bus must be isolated
You keep grounds & neutrals seperate
I don't buy 15a breakers - only 20a, they are about the same price
By only using 20a you can just buy one roll of 12-2 wire
Otherwise you would need to buy 12-2 for the 20a & 14-2 for the 15a
Make sure your treadmill will run on a 15a circuit of you decide to go that route
Old 11-29-2009, 04:17 PM   #3
Oh....and can I use 12-2 wire on a 15 amp circuit?
Old 11-29-2009, 04:31 PM   #4
Licensed electrician
Rewards Points: 1,028
There is no problem with #12 on a 15 amp breaker. With a 20 amp breaker you can get an additional 1/3 capacity over the 15 amp.
Old 11-29-2009, 04:38 PM   #5
A little more info on the load box
I just tested a piecde of 10 awg in the main feed screw slot. Nice tight fit and good indentation on wire.....I assume this is what we want to see here?
Thanks alll!
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 06:47 PM
