Help!! So Confused On Wiring Dimmers! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 12:21 PM   #16
One of the white wires could be a hot if the feed went into a light first.
Holy Funk is offline   Reply With Quote
Old 12-12-2011, 12:56 PM   #17
Thanks Stubbie, that diagram really helped me!!
Cheers and Merry Christmas
Skylaa is offline   Reply With Quote
Old 12-12-2011, 12:58 PM   #18
I think all the whites were together..( I wasnt the one that pulled it all apart, so Im not sure..but they do have the whites together for all the normal switches
Old 12-12-2011, 01:37 PM   #19
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Your welcome ... my off the wall guess is you were tripping your breaker because you were connecting a neutral (white) to your switch. As Speedy said earlier you only needed to connect the two wires that were connected to the regular switches to the 2 blacks of your dimmer and connect the green ground to the metal box. Just put the green under one of the screws with the other grounds.
If all the whites were connected together then only black wires should be connected to your dimmers ... the feed black and then the black that goes to the lights. You have to connect the feed black (power) to all the switches. It is possible you may have more than one feed (power) that's one of the reasons Speedy was telling you to sort out the wires so you know what is feed (power) and what goes to the lighting loads. It is possible you have more than one feed entering that switch box so you need to check.
Looking at your diagram you have a white and black connected to a regular switch is that working properly or tripping the breaker?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 12-12-2011, 10:59 PM   #20
Your off the wall guess was Bang On!! The white did get connected to the Dimmer, so it not only blew the breaker but BOTH Dimmers !! I had a electrician look at it, he pigtailed off the hot, and then black to black and all works fine now
Expensive lesson learned, but worth having it safe and done right!!
Thanks again for your help
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 07:52 PM
confused re wiring on ceiling light stel Electrical 6 08-07-2011 03:22 PM
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 10:03 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Confused about Sub Panel stqevo Electrical 28 10-02-2009 12:04 AM
