Help!! So Confused On Wiring Dimmers! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 08:52 PM   #1
Exclamation
Help!! So confused on wiring dimmers!
Hello,
I recently renoed my basement and had electricians in to redo everything, including installing a new panel. I installed 10 pot lights and told the electricians that I would like to have them on 2 dimmer switches. They installed 2 normal switches until the drywall was finished. The drywall is now finished, and I want to install 2 dimmers now, but everything I tried keeps blowing the breaker(the dimmers I am installing are LUTRON Diva 120v dimmers. I know 6 potlights were on one switch and 4 on the other. I think they had all the neutral wires nutted, but not sure. The dimmers have 2 black wires and 1 green, Please help
sky
Help!! So confused on wiring dimmers!-194604_10150523879430465_717725464_10819924_1768828390_o.jpg
Skylaa is offline   Reply With Quote
Old 12-11-2011, 08:56 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
WHY didn't you simply take the two wires off each switch and put them on the two wires from the dimmer???
Old 12-11-2011, 08:58 PM   #3
You need to identify the wires to the lights and the feeds.
Why is there a 3-gang box? What is the other switch/cable for?
Old 12-11-2011, 09:04 PM   #4
Licensed electrician
Rewards Points: 1,266
Why are the whites spliced that way? There is no need for a jumper between the whites.
Old 12-11-2011, 09:06 PM   #5
The 3rd slot is for another ordinary light switch, forgot to mention that, sorryy
Old 12-11-2011, 09:09 PM   #6
After several tries, I just wire nutted everything and shut it all off. I think the whites were all together before
Old 12-11-2011, 09:22 PM   #7
OK, I have figured out the lights and the feeds, now, how do I hook it up?
Old 12-11-2011, 09:26 PM   #8
One feed and one light to each dimmer.
Skylaa (12-12-2011)
Old 12-11-2011, 09:55 PM   #9
OK, but what about the whites....do I wire them all together or leave them seperated?
Old 12-12-2011, 04:55 AM   #10
dmxtothemax's Avatar
Rewards Points: 5,102
The whites are normally neutral,
Not all dimmers need a neutral.
Just leave the whites capped.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Skylaa (12-12-2011)
Old 12-12-2011, 05:28 AM   #11
Rewards Points: 730
Is that really one EGC to a screw at the back of the box. If so, this installation violates the free conductor rule.
Mark
busman is offline   Reply With Quote
Old 12-12-2011, 08:05 AM   #12
Mark
The Op is in Canada. Their rules might be different.
Old 12-12-2011, 08:20 AM   #13
Rewards Points: 730
I did notice that the OP was in Canada, but I'm having a hard time accepting that a 1.5" conductor would be legal up north.
Mark
Old 12-12-2011, 11:36 AM   #14
Not sure what an EGC is, but I do know they screwed the grounds to the back of the box, had all the whites wirenutted together. When my friend took it apart, there was 2 black pig tails and one white.....,
Thank you for all of your help, I will try it one more time but will call an Electrician if it doesn't work.....
Old 12-12-2011, 12:03 PM   #15
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
This is the lutron wiring diagram for the DIVA single pole
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
Skylaa (12-12-2011)
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 07:52 PM
confused re wiring on ceiling light stel Electrical 6 08-07-2011 03:22 PM
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 10:03 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Confused about Sub Panel stqevo Electrical 28 10-02-2009 12:04 AM
