Help! Romex To A Light Socket, What To Do With Ground Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 05:13 PM   #1
Rewards Points: 101
Help! Romex to a light socket, what to do with ground wire?
Sorry, I'm in the middle of the project and don't have time to do extensive Google Search. Hope I can get a quick answer from the forum.
I'm replacing the old knob and tubes. We have this outside light that basically is just a light socket hanging off of a metal tube that goes from the attic to the outside. I've taken the socket out by disconnecting the old hot and neutral wires. Now, I have pushed a 14-2 Romex through the metal tube and need to hook the cable up to the socket. There is not a ground screw in the socket. What do I do with the ground wire?
mudworm is offline   Reply With Quote
Old 12-04-2011, 06:21 PM   #2
Electrical Contractor
kbsparky's Avatar
I would look for a suitable place to install some sort of grounding screw on the frame of the fixture, and connect it there.
-KB
Old 12-05-2011, 12:40 AM   #3
Rewards Points: 101
Thanks. This is with a porcelain socket. I went ahead and bent the ground wire backward to tuck it back into the metal tube. If the inspector notices it and doesn't like it, I'll change it then.
Old 12-05-2011, 03:28 AM   #4
liscenced electrician
Rewards Points: 538
Get a ground clip or drill and tap a 10-32 ground screw somewhere
jimmy21 is offline   Reply With Quote
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
Yard Light Ground... dean830 Electrical 6 06-09-2011 02:58 AM
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 09:08 PM
Light fixture needs a ground wire PRedLSU Electrical 4 05-23-2010 10:35 PM
Light cord to screw in socket adapter? Charger Electrical 11 05-02-2010 07:04 PM
