Help With Rewiring A Switch For Vacuum Cleaner - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2013, 04:58 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Help with rewiring a switch for vacuum cleaner
I have an old filter queen vacuum cleaner that needs a new switch.
Would anyone be able to help me with wiring it up?
The switch has one wire, the motor has 2 black wires, and the electrical plus has a white and a black.
I did wire my lights when I renovated the basement but I forgot.....lol
I have a thought on how I should do it, but don't really know for sure.
Thank you so much all you wonderful people.
http://diyitnow.blogspot.com
yummy mummy is offline   Reply With Quote
Old 11-10-2013, 05:13 PM   #2
Rewards Points: 582
the switch should have wire in and out..? motor---one wire to white on cord..black from cord to switch.. other side of switch to other motor wire.. ben sr
Old 11-10-2013, 06:13 PM   #3
Thanks for your response. The switch only has one wire. It is an on and off switch that has a little pedal.
Thanks for your wiring advice. I will try tomorrow when I get the new switch.
Old 11-10-2013, 08:22 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,098
There should be two wires on the switch !
Look carefully ! is there another one ?
where does it go ?
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
ben's plumbing (11-10-2013)
Old 11-10-2013, 09:08 PM   #5
joed's Avatar
Rewards Points: 11,614
A switch has to have two wires. One for power in and one for switched power out.
One of the switch wires goes to the black from the power cable. The other one goes to the motor.
The Following User Says Thank You to joed For This Useful Post:
Old 11-10-2013, 10:40 PM   #6
Thanks for all your help.
Unless I am off my rocker, which is always a possibility..... the switch only has one wire. I have attached a picture of the switch. It is the old one. I have seen the new switch and it looks exactly the same, only one wire.
Do I need to put two wires together somehow somewhere?
Old 11-10-2013, 11:11 PM   #7
[QUOTE=yummy mummy;1265138]Thanks for all your help.
Attachment 77761
That switch is broken, you can see on the left side.
Thats where the other wire should have been !
Your new switch should have two connecttions on it,
Usually one at each end.
Look carefully at both ends.
Old 11-10-2013, 11:42 PM   #8
Yes, that switch is broken because I tried to pry it open as I saw a you tube video showing that you can repair the switch that is why it looks broken, but I have been to the store and seen the new switch and it only has one wire.
The switch was connected but I removed it, and don't remember how to put it back, so I wanted to find out before I purchase the new one.
The new one only has one wire. The button on top opens the vacuum cleaner and closes it.
Old 11-11-2013, 12:21 AM   #9
dmx, I just ripped open that switch......
It does look like there should be another wire on the other end. What the hell did I do with it.....lol OMG now I am really confused.
I am certain that the new switch that I saw at the vacuum store only has one wire. It probably had 9, but with my old age and my apparent memory loss, who remembers.
Ok, I will go and look again tomorrow to see the new switch, it better have 2 wires. What would I do without you guys here to help me. Love you guys and gals
Old 11-11-2013, 03:07 AM   #10
The wires are normally held in place by a small grub screw,
If it's loose, the wire can easily fall out,
Thats probably why there's only one wire in your new switch,
The other has probably fallen out.
You will need good eye's,
a small screw driver,
plus some more wire to fix it !
Old 11-11-2013, 08:16 AM   #11
Thank dmx for your help.
I don't have the new switch, I just saw it at the store. I am going to go and see today.
Old 11-11-2013, 10:05 AM   #12
joed's Avatar
When you get the new switch with two wires this is your connections.
One motor wire goes to the white power wire.
The other motor wire goes one switch wire.
The other switch wire goes to the black power wire.
Old 11-13-2013, 01:27 PM   #13
Well, people, I have officially declared myself with temporary memory loss.....lol
The switch has two wires. I apologize to all for my lack of memory.....
I just picked up the switch and will follow your wonderful instructions on how to wire it.
Thanks again.
What would I do without this place.
The Following User Says Thank You to yummy mummy For This Useful Post:
ben's plumbing (11-13-2013)
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
taco sr503-4 switch jmon HVAC 53 11-12-2012 07:26 PM
3-way switch help amit Electrical 17 02-15-2010 04:17 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
