01-24-2013, 02:41 PM
#1
Help with rewireing basement
I have attached a file it is of my basement electrical / light outlets.
I was wondering how many wires i would need to run from the fuse box, and , also how many electric sockets i can connect to 12 gauge wire going into the fuse box.
Thank you for any help
Paul
01-24-2013, 02:51 PM
#2
Lic Electrical Inspector
Posting your location will help. There is no limit to the number of receptacles on a general lighting circuit. You need one 15A circuit for every 600 sq ft of living space or, one 20A gen lighting circuit for every 800 sq ft.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
The Following User Says Thank You to electures For This Useful Post:
01-24-2013, 03:05 PM
#3
Live in Illinois
01-24-2013, 03:46 PM
#4
Then you might need to run it all in conduit. What part of Illinois?
It also depends on what you intend to plug into the receptacles. Any place you might use a heater should have less devices on the circuit. The TV location would be a good idea to be on separate circuit although not required.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
01-24-2013, 03:51 PM
#5
Litchfield illinois..
Thank you for the information... also should i run the refridge on one line,or can i connect a few lights and electric sockets to the same line?
01-24-2013, 04:04 PM
#6
Do you think these wires look ok?
01-24-2013, 04:13 PM
#7
Electrical Contractor
You may also need afci breakers and smoke detectors.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
01-24-2013, 04:47 PM
#8
I thought i could maybe rewire my basement like the picture shows?
01-24-2013, 09:13 PM
#9
Eliminate the unnecessary JB's.
01-24-2013, 09:58 PM
#10
Im sorry but what are JB's ?
01-24-2013, 10:23 PM
#11
Junction Boxes.
01-25-2013, 07:30 AM
#12
Originally Posted by joed
Junction Boxes.
Ok, Junction boxes,, how many wires can you have going into one junction box?
01-25-2013, 08:25 AM
#13
Depends on the size of the wire and the size of the junction box. There is a calculation call 'box fill' that needs to be done.
01-25-2013, 08:33 AM
#14
Not to be rude, but your posts suggest to me that you have little or no knowledge of electricity or wiring. If that is the case, please don't even attempt this project until you do some studying. There is an excellent little book called "Wiring Simplified" that will greatly help you. It's sold in most big box stores, and is in the Electrical section, not where the other books are. Costs something like $12.
The Following User Says Thank You to md2lgyk For This Useful Post:
01-25-2013, 09:06 AM
#15
Yes very little knowledge of electricity and wiring, i will get the book thank you
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
