Help Requested For Changing Double Switch To Two Singles - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 08:44 PM   #16
TTW
TTW's Avatar
They make 3 way dimmer switches. Not sure if this is what you are asking.
TTW is offline   Reply With Quote
Old 11-28-2012, 09:09 PM   #17
Sorry my question was unclear. What I'm asking is whether I can add one of the lights now controlled by one of the single switches (see Hammerlane's diagram I've reproduced here) to the existing three way switch in the same box.
eddj is offline   Reply With Quote
Old 11-28-2012, 09:12 PM   #18
JuzRick's Avatar
TTW: A possibility OP maybe asking also as an option, if using one of the existing switch legs as a traveler to tying onto both switches formatting it as a 3 conductor. But he would still need that additional conductor.
Your hot then, lamp and traveler.
JuzRick is offline   Reply With Quote
Old 11-28-2012, 09:18 PM   #19
JuzRick's Avatar
Eddj: I see it as being possible depending on how its run now.. as for the lights setup. You could be short a couple feet of wire. 14-3 conductor is required, code that is for 3-4, way purposes.
Don't want to steer you in the wrong direction either- but it can be done.
Old 11-28-2012, 09:41 PM   #20
Does the additional wiring have to take place AT THE LIGHT itself or can it happen IN THE BOX where the switches are. If I have to change the wiring at the lights, I would need to do some work in my attic which I'm not up for right now.
Here's the diagram with the switch leg and connections to the 3 way labeled.
Thanks for your help.
Old 11-29-2012, 12:41 AM   #21
JuzRick's Avatar
DEPENDING HOW THE CONDUCTORS(WIRES) ARE RAN IN THE CEILING WHERE YOUR LIGHTS ARE, DEPENDS ON HOW YOU WILL HAVE TO REROUTE THE CONDUCTORS. I WOULD SUGGEST YOU PURCHASE 14-3 FOR YOUR 3-WAY CONDUCTOR(YOUR TRAVELERS) VS TRYING TO RIG IT TO WHERE IT WILL WORK. DEPENDING ON HOW YOU COMING OFF THE LIGHT(S) ITS POSSIBLE YOU CAN USE THE SAME 14-2 CONDUCTOR CURRENTLY INSTALLED. IF TWO LIGHTS, TAKE 14-2 AND JUMP FROM THE PRIMARY LIGHT CONNECTING TO THE 2ND LIGHT.
I KNOW BACK IN THE DAYS IT WAS DONE USING 3 SETS OF 14-2 CONDUCTORS, a) ONE FULL LINE- FROM PRIMARY SWITCH BRANCHED TO THE 2ND 3-WAY SWITCH b) 2ND BLACK CONDUCTOR GOING FROM SWITCH LEG TO LIGHT, AND THEN THE 3RD BLACK AS THE TRAVELER c) SWITCH TO SWITCH(ONE ITS LEGS). BUT WE MUST KEEP IN CONSIDERATION WHY CODE IS WHAT IT IS.. AND NEC.
TO PROTECT THE WELL BEING, SAFETY OF HOMES, PEOPLE IN HOMES. DEPENDING ON THE DISTANCE OF THE 2ND 3-WAY SWITCH FROM THE PRIMARY SWITCH THAT IS IN THE BOX YOU JUST REPLACED. THE PRICE ON THE WIRE PROBABLY AT $40.00-$60.00(25'FT-50'FT ROLL), IF ANYTHING.
FORTY-SIXTY DOLLARS SPENDING ITS CHEAP COMPARED TO YOUR LIFE BEING AT STEAK. NOT SAYING YOUR NOT CAPABLE OF DOING IT.. JUST THINKING SAFETY!
3-WAY DIAGRAM USING 14-3 AND 14-2 CONDUCTORS
http://www.easy-do-it-yourself-home-...y-switch-1.jpg
Old 11-29-2012, 06:30 AM   #22
TTW
TTW's Avatar
Take a meter or tester, put one lead on the white neutral in the box, hold the other lead on the black terminal on your three way switch.
Please be careful!
then operate both 3 way switches.
If you have voltage on that black terminal when the lights are on, and the voltage turns off when the lights turn off (this is the important one), then you will be able to do what you want to do.
If that voltage stays on all the time, you will not be able to wire the other lights into the 3 way in your box.
In that case, probably the easiest thing to do will be to connect the other lights to your 3 way switched lights up in the attic.
The Following User Says Thank You to TTW For This Useful Post:
eddj (11-29-2012)
Old 11-29-2012, 07:52 AM   #23
Rewards Points: 2,516
What I'm asking is whether I can add one of the lights now controlled by one of the single switches to the existing three way switch in the same box.
So you would like to have say light "B" controlled by 3-way switch "E". Well then why did you want the 2 single pole switches "C" and "D"? Would you leave switch "D" in the 3-gang box and just have it non-functional?
hammerlane is offline   Reply With Quote
Old 11-29-2012, 08:15 AM   #24
Does the additional wiring have to take place AT THE LIGHT itself or can it happen IN THE BOX where the switches are. .
If the 3-way in the 3-gang box is the 3-way where the power originates you cannot switch the other light via the 3-gang box. In other words if the set up is like the below diagram:
Old 11-29-2012, 08:16 AM   #25
What you will have to do is get the switched hot from 3-way "F" to control the other light...kind of like below:
In the diagram below, switch "C" controls lite "A", switch "D" controls nothing and switches "E" and "F" control lites "B" , "G" and "H"
The Following User Says Thank You to hammerlane For This Useful Post:
eddj (11-29-2012)
Old 11-29-2012, 09:02 AM   #26
Yes, it would be non-functional. We didn't realize we would prefer all the recessed lighting on the same three way until I actually made the change. It's just more convenient having access to the lights from where the two three way switches are positioned. I learned a lot from making the switch regardless and thanks again for your help.
Old 11-29-2012, 10:08 AM   #27
Unfortunately, this is my situation. Power is coming into the three gang box. So I will just leave things as they are for now. Later I'm going to have to remove one of the recessed lights that is already on the three way (it is in the way of a range hood I'm going to install) and I'll see if I can hook up the wiring in the attic from this light to the light that I want to tie in. Should be possible. The lights are only about five feet from each other.
Can't tell you how much I appreciate the guidance in this forum.
The Following User Says Thank You to eddj For This Useful Post:
TTW (11-29-2012)
Old 12-01-2012, 01:04 AM   #28
JuzRick's Avatar
Eddy: your welcome sir...
Help wiring for double switch - and why the hot white wire? BusterT Electrical 4 10-20-2012 12:37 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Double switch for two light bulbs Rnj Electrical 15 08-22-2010 02:37 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
