Help With Replacing Under Cabinet Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 01:45 PM   #1
Help with replacing under cabinet lights
I can not find parts to repair my old under cabinet lights in my kitchen so I need to replace them. I received a suggestion from a local lighting store to use LED strip lighting. Is this something I can do myself? Is the job easier with existing hardwire? Is the light they give off bright enough? I have never attempted anything electrical.
Any suggestions will be appreciated.
miami mama is offline   Reply With Quote
Old 09-30-2011, 05:09 AM   #2
dSilanskas's Avatar
LED lighting is surprisingly bright. However if you haven't ever done electrical before I'd suggest having someone come in and do it. Watch them to see what they do if you want to learn a little. Or by a book to learn a little more about it.
dSilanskas is offline   Reply With Quote
Old 09-30-2011, 11:23 AM   #3
help with replacing under cabinet lights
Thanks for your advice. It is definitely a cheaper way to go. I will try it.
Old 10-20-2011, 09:53 PM   #4
Canadian home owner
Along the lines of LED under cabinet lighting and for Canadian code, can I install a switched outlet fed from the kitchen light on the wall above the upper cabinet to plug in the transformer for the lights?
pw5599 is offline   Reply With Quote
Old 10-20-2011, 10:03 PM   #5
Rewards Points: 14
LED under cabinet lighting is excellent. Definitely the way to go. If you have a switched in the cabinet above the fridge or above the microwave (assuming you have a microwave hanging above the stove) then all you have to do is run the low-voltage wire that comes with the lights to the adapter at the switched outlet and plug it in. Then mount the lights.
Jakobud is offline   Reply With Quote
After replacing a light fixture the fan is not working but the lights do aniamaja Electrical 9 07-14-2011 08:23 AM
How to terminate under cabinet lights mark_anderson_u Electrical 2 12-07-2010 07:26 AM
Under cabinet Light Suggestions jamiedolan Electrical 7 04-01-2009 11:59 AM
Replacing hall light fixtures with recessed lights POMEXCAN Electrical 3 04-16-2008 10:40 PM
Replacing Dimmer for kitchen lights tmcguirk Electrical 2 04-16-2008 08:38 PM
