Help Replacing T12 Ballast - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 01:20 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Good god...its a garage shop light...not the entry fixture at a 5 star hotel.
The Following User Says Thank You to k_buz For This Useful Post:
Missouri Bound (06-21-2012)
Old 06-21-2012, 03:33 PM   #17
Rewards Points: 266
It requires more attention that the 5-star hotel. Done correctly, It won't have to be touched for 20 years, not even the lamps. The luminaires in 5-star hotels probably get changed 2-4 times that often in the required remodels.
ionized is offline   Reply With Quote
Old 06-21-2012, 03:40 PM   #18
Missouri Bound's Avatar
It's no wonder that so many OP's never return to the forum. Their intelligence is insulted, they are overwhelmed, or when they ask the time somebody tries to tell them how to make a clock. This isn't rocket science and for the record, I have had Home Depot lights in my garage for 5 years...no problem. T-8's with 4 bulbs in an 8' fixture. Keep it simple!
Do you want it your way or the right way?
Old 06-21-2012, 03:57 PM   #19
Rewards Points: 776
I was in my garage yesterday and noticed the fluorescent lamps cast a terrible hue on the oil stain on the floor. What is a person to do? Oh the humanity of it!
curiousB is offline   Reply With Quote
Old 06-21-2012, 05:41 PM   #20
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I think you should go install it for the OP and warranty it also.
Old 06-21-2012, 05:46 PM   #21
k_buz's Avatar
Let me guess...you are one of two things....
1) Engineer
2) Lighting salesman
Old 06-21-2012, 07:01 PM   #22
Rewards Points: 266
Just clean up the oil or use better lamps. It is simple, really.
Old 06-21-2012, 07:05 PM   #23
Rewards Points: 266
1) Engineer
Neither, keep guessing. I do own a house that an electrician owned and lived in for 40+ years. That keeps me busy between his salvaged, non-residential equipment and electrical stuff that was done in haste.
Old 06-21-2012, 07:05 PM   #24
Rewards Points: 266
I'd do it as a favor if he lived close by.
Old 06-21-2012, 08:02 PM   #25
Now that's a bunch of bull
Old 06-21-2012, 08:56 PM   #26
Rewards Points: 266
I made some reasonable assumptions and did some kindergarden arithmetic. What are you basing your conclusion on?
Old 06-21-2012, 09:00 PM   #27
Licensed electrician
Rewards Points: 1,300
I must be lucky. My CFL bulbs in the garage are constantly being switched on and off and are base up and have lasted for years.
Old 06-21-2012, 09:02 PM   #28
Flourescent lamps will not last 20 years under any circumstances, unless never turned on. Better theck your arithmetic.
Old 06-22-2012, 12:31 AM   #29
Rewards Points: 266
I sure hope the OP comes back tonight at some of his usual vampire-like times. This thread has been taken way OT.
hugocraft, please come back. There are good answers here for you.
Old 06-22-2012, 12:42 AM   #30
Maybe we scared him......
New T5 Ballast causing Blinking gray0239 Electrical 3 01-05-2012 12:37 AM
T12 ballast to T8 c.bustle Electrical 5 07-10-2011 11:33 AM
Replacing Ballast rjgorman Electrical 10 06-30-2011 06:20 AM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 05:02 AM
Replacing kitchen ballast jknober Electrical 5 10-12-2008 09:48 PM
