Help Replacing Ceiling Light- UK - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 05:20 PM   #1
Help replacing ceiling light- UK
I need some help to wire up a new light fixture
I took down my old light fixture and I have never seen anything like it
3 red wires- All connected to each other but nothing else
3 bares wires(all connected but nothing else)(these are the earth)
3 black wires- all connected at different points- I am assuming this is the wiring loop
THe new light fixture had a single adaptor for Live,Nuetral and earth so I connected all 3 red into a block and then into the new light, same with the earth
Now I cannot figure how to configure the black wires - I have ascertained which is the main live wire- I connected it individually to the light and once I turned the fusebox back on the light was on constantly
However witht he 2 other wires I am unsure of how to integrate them to allow the switch to work
I have left all the black wires disconected and capped while I try to figure it out, however now half of my upstairs lights dont work
Can anyone guide me on how to install these correctly?
DMGunner is offline   Reply With Quote
Old 12-21-2012, 09:41 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Bonsoir DMGunner.,
Look at the last two conductors if you see it have sleeved conductor that is the switch loop format so one of the switch loop conductor will be hooked to the black conductor the other one will go to the luminaire ( brown colour for modern code ) and the bleu conductor will go to old black conductor ( netural )
And look at the switch point to make sure the colours are matched up before you turn it back on.
Hunter Ceiling Fan & Light control #27182 slrholmes Electrical 23 03-28-2014 05:46 AM
Adding Ceiling Light Raxas Electrical 3 05-13-2012 01:00 PM
Replacing light with ceiling fan magnolia Electrical 4 11-09-2011 12:29 PM
Installed Ceiling Fan Light Kit - No Lights soulstar Electrical 10 11-09-2011 11:35 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
