HELP! Probs W/ Flourescent Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2009, 12:34 PM   #1
Question
HELP! Probs w/ Flourescent Light Fixture
I have a two bulb flourescent light fixture in our kitchen. The bulbs went out. I replaced them, they did not come on, replaced ballast and during the process one of the bulb pin connectors broke, I replaced that, installed the bulbs and one will come one and the other will not, switched the light bulbs around...still same problem with the same side....what have I done wrong????
OWNLEY is offline   Reply With Quote
Old 06-12-2009, 03:26 PM   #2
Check the rest of the tombstones. The wiring that pokes in there often gets loose.
Make sure the lamp pins are in correctly. It's easy for them to pop out when the lamps are installed.
Make sure the ballast you installed is 2 lamp/120V
Check all wire nutted connections
I HATE flourescent bi pin tube lamps/sockets BTW. I always seem to struggle with them. Give me 8 footers any day
220/221 is offline   Reply With Quote
Old 06-12-2009, 03:33 PM   #3
DIY'r
ScottR's Avatar
Never heard that term before, and it took me a second.. but I like it.
OWNLEY, I just had a problem the other day where the frame of the fixture was bent, and the tombstone () was pushed out just a little bit. Enough that the bulb wan't connecting electrically, but was seating. I didn't notice it at first.. Check the metal, it's easily bent on the cheaper fixtures like mine.
ScottR is offline   Reply With Quote
Old 06-12-2009, 06:38 PM   #4
300zx's Avatar
+1 I Have had them wires come out of the tombstone they just push in
300zx is offline   Reply With Quote
Old 06-12-2009, 08:12 PM   #5
Thanks!
Thanks for the help, I need a bit of explanation on the tombstone...I just a simple country gal
Old 06-12-2009, 08:15 PM   #6
Got the Tombstone
Nevermind I just figured out- what tombstone is....the plastic piece that holds the pins that the bulb sits in??
Old 06-13-2009, 01:15 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Yep., Ya got it right there.
and make sure the tombstone line up correct { not in corked (not straight ) at all if corked it may lit up or not lit up at all.
{ especally true with rapid start ballast }
Merci,Marc
Old 06-13-2009, 10:32 AM   #8
Name
I am sure you know how they got their name now don't you????????
SULTINI is offline   Reply With Quote
Old 06-13-2009, 11:06 AM   #9
Rewards Points: 894
Many times while installing double pin tubes I get one pin in and one pin out of the socket. I have also found that the sockets, or tombstones as others are referring are flimsy, and the contacts don't hold the lamps too well.
I have also had the wires pull out as well.
Where has the quality gone?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 06-13-2009, 02:28 PM   #10
DIY'r
ScottR's Avatar
Amen. 25 bucks for a single tube fixture @ HD. Sheet metal is thinner than a piece of paper, and about as flimsy.
Old 06-14-2009, 12:54 PM   #11
Rewards Points: 160
No I don't. They do look like the shape of a tombstone. What say you?
OP. Get some new lamps. I always find at least one bad one in every case of new ones I have bought. Sometimes we make things complicated. It very well could be a lamp (bulb). It takes two for the light to work, even if one comes on by itself.
Ps....I missed your comment about moving bulbs and the problem followed on the same side. Ballast or connections are your next step.
Multi-wiring one flourescent light fixture... cjkline83 Electrical 4 01-06-2009 08:50 AM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 09:46 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
