Help With Power - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2009, 08:58 PM   #1
Help with power
Plugged in a small microwave into an outlet that was working with no problems. Heard a slight noise and unplugged it. One of the prongs look a little burnt. Now outlet does not work. I checked all the outlets with the breaker off and found 4 on that circuit. 2 work, 2 do not. I disconnected all wires from these outlets and turned breaker on. Outlet #1 has 2 pair of wires 1 has power the other pair I found by using my Ohmmeter feeds Outlet #2. #2 only has one pair (end of run?). Outlet number 3 has 2 pair. 1 pair feeds outlet #4 (verified with Ohmmeter) which only has 1 pair. The other pair in outlet #3 has no power. How do I find what feeds the power to #3?
boscru6469 is offline   Reply With Quote
Old 08-05-2009, 09:04 PM   #2
dSilanskas's Avatar
If your talking about a kitchen check your fridge outlet
dSilanskas is offline   Reply With Quote
Old 08-06-2009, 10:08 AM   #3
I checked every outlet in the house and can only come up with these 4 being on the same circuit. fridge outlet ok.
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
