HELP! Please. How To Wire A Light, Switch, Then Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 12:02 AM   #1
HELP! Please. how to wire a light, switch, then outlet
hi, 1st post! searched the previous threads for ever - and no luck
I have power through romex 14/2 to a pull light. I added a switch to it, from the light. in the original config, it was always hot and had an outlet off the pull light.
is it possible to have a hot outlet after a pull light that recieves power to a terminal switch????? and if so, any help as to how to do this would be greatly appreciated.
My Dad and I could not figure it out and i was attempting to sell the benifits of this site..... thanks so much in advance - hope the 4th was as good for you as it was for us-
-dave
dcwright is offline   Reply With Quote
Old 07-06-2009, 12:19 AM   #2
Journeyman Wireman
Yes it's possible. The black wire going to the recept needs to make up with the hot before it goes to the switch. The neutral should stay the same.
jbberns is offline   Reply With Quote
Old 07-06-2009, 04:46 AM   #3
That makes no sense.....to me.
Maybe this will help.
At the light, black= hot and white= neutral.
At the recep, black= hot and white= neutral.
At a switch (loop), white= hot, black = switch leg
220/221 is offline   Reply With Quote
Old 07-06-2009, 06:17 AM   #4
Electrical Contractor
kbsparky's Avatar
If you are using one of those porcelain pull-chain type fixtures with an integral outlet it is not possible to accomplish your goal of having the outlet always on, with the light socket controlled by a wall switch.
-KB
Old 07-06-2009, 08:52 AM   #5
Journeyman Wireman
-dave
My "interpretation" is he has a light and a recept already on a circuit. And is adding a s/p switch (terminal switch???) to control the light.
Old 07-06-2009, 07:11 PM   #6
kbsparky's Avatar
What do you consider a "pull light" to be?
-KB
Old 07-06-2009, 07:51 PM   #7
joed's Avatar
Rewards Points: 12,924
I'm lost as to what are trying to do.
1. Is it power - light - switch - receptacle.
2. Is it power - light - switch and then light - receptacle.
I think you want #2.
But if you want #1 then
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Separating Fan and Light Switches GeauxCajuns82 Electrical 11 08-26-2008 12:03 AM
Overhead light w/ switch and 3 recept. how to wire? twilightcall Electrical 8 01-07-2008 04:27 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
