HELP, Please.. Do I Really Need This Work Done???? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 10:05 AM   #31
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Even the power companies still use aluminum to feed most homes today because of the cost. My electric service and 200 amp sub panel work great with aluminum and we use a lot of power with a tankless water heater. Properly made connections and use of ox guard make it just as copper. Would have cost over 2,000 for CU and was 300 for AL.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-04-2013, 12:01 PM   #32
rrolleston's Avatar
Originally Posted by jeffnc View Post
I wasn't too clear. I was trying to say that if Cu and Al did cost the same, electricians would still use Cu.
I understand, it's just not an issue. The current draw for your water heater is not near the current limit of the wire, so Al or Cu don't matter in this respect.
Tankless water heater and my all electric home can see usages very close to the wires capacity. Tankless water heater alone can draw close to 120 amps at our full usage electric hear cooking dishwasher garage with compressor welder. I am damn near capacity sometimes.
Old 01-04-2013, 12:12 PM   #33
Rewards Points: 4,796
ha, sorry, thought you were trying to work a gas water heater into an electrical conversation, my bad.
Anyway, yes, of course there is no issue if the Al wire is sized correctly. But if Al and Cu cost the same, they would use Cu, because a smaller wire could carry the same current.
jeffnc is offline   Reply With Quote
Old 01-04-2013, 12:37 PM   #34
rrolleston's Avatar
Of course we would use CU if it cost the same but it don't so for large feeders to breaker panels many people use AL with no problems at all.
There is no reason to replace a perfectly good working AL feed.
For someone to suggest that AL feed needs to be replaced from those pics is crazy.
Old 01-04-2013, 12:41 PM   #35
Agreed.
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 01:45 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
