Help Please- 2 Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2007, 09:39 PM   #1
Help please- 2 questions
Can industrial electricians work on wiring in residential homes?
How do I change the AMPs in the house
exp My house AMps is 100amp how do I change to 200amp? And is industrial electricians allowed to do it?
thank you
August guo is offline   Reply With Quote
Old 08-12-2007, 09:47 PM   #2
Eibwen
In most areas an Electrician needs to be licensed for the municilpality he is working in. Assuming that, then yes he can do it.
To upgrade the service, the panel needs to be upgraded and possibly the line for the transfomer if it is undersized.
Sammy is offline   Reply With Quote
Old 08-12-2007, 09:57 PM   #3
Thanks for your answer, can industrial electricians change the panel?
I am a certified Ontario industrial electrician, are you sure I can wire in residential house?
Old 08-12-2007, 10:01 PM   #4
Eibwen
Your welcome.
Not sure on the local requirements, but check with the licensing authority and if they say its o.k. your good to go.
Old 08-12-2007, 10:08 PM   #5
Agent 000
SecretSquirrel's Avatar
Not sure how they do it in Canada but here in the US you have to have an Electrical Contractors License or work for someone that has an Electrical Contractors license to perform electrical work. The person performing the work usually has to be a certified Journeyman or Master electrician. This could vary from state to state. I would suggest you talk to your local electrical inspection department and have them tell you the specific requirements.
SecretSquirrel is offline   Reply With Quote
Old 08-12-2007, 10:17 PM   #6
Also, do I need to upgrade the main wire that come from outside?
Old 08-12-2007, 10:21 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
1) It certainly does vary from area to area. In my area there are only a few places you need a license of any kind. The other places anyone can do the work. I do NOT agree with this policy but that's the way it is.
NYS is messed up as far as electrical licensing and regulation goes.
2) August, you are "a certified Ontario industrial electrician", and you have to ask the question: "How do I change the AMPs in the house"???
Are you for real?
How long have you been "a certified Ontario industrial electrician"?
Old 08-12-2007, 10:23 PM   #8
To answer your question. Everything from the connections at the drop, down to the meter pan, SE cables, panel and grounding need to be upgraded.
The drop from the street is typically the POCOs property.
Old 08-14-2007, 10:26 PM   #9
I am a newcomer to Canada, I know how to do it but I don't know if I'm allowed to do it with my license, because there is also construction electrician
Old 08-15-2007, 09:43 PM   #10
Then whats the difference between construction electrician and electrical electrician?
Old 08-15-2007, 09:46 PM   #11
IMO nothing.
Maybe Canada has different rules/titles for who can do what type of work.
Old 08-15-2007, 09:47 PM   #12
So Industrial electrician can do whatever electrical electrician?
Old 08-15-2007, 10:06 PM   #13
Let's wait for a reply from someone who knows Canadian codes.
Old 08-15-2007, 10:29 PM   #14
Okay, sure well anyway thanks for your help
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
some questions on masonry/cement/concrete (general q's) joeyboy Building & Construction 20 06-25-2007 09:53 PM
questions about wood shake roof oraph Roofing/Siding 4 10-26-2006 06:10 AM
Main/Sub/Garage Gen Backup Questions crecore Electrical 9 04-17-2006 07:31 PM
