Help please- 2 questions
Can industrial electricians work on wiring in residential homes?
How do I change the AMPs in the house exp My house AMps is 100amp how do I change to 200amp? And is industrial electricians allowed to do it? thank you |
In most areas an Electrician needs to be licensed for the municilpality he is working in. Assuming that, then yes he can do it.
To upgrade the service, the panel needs to be upgraded and possibly the line for the transfomer if it is undersized. |
Thanks for your answer, can industrial electricians change the panel?
I am a certified Ontario industrial electrician, are you sure I can wire in residential house? |
Your welcome.
Not sure on the local requirements, but check with the licensing authority and if they say its o.k. your good to go. |
1) It certainly does vary from area to area. In my area there are only a few places you need a license of any kind. The other places anyone can do the work. I do NOT agree with this policy but that's the way it is.
NYS is messed up as far as electrical licensing and regulation goes. 2) August, you are "a certified Ontario industrial electrician", and you have to ask the question: "How do I change the AMPs in the house"??? Are you for real? How long have you been "a certified Ontario industrial electrician"? |
To answer your question. Everything from the connections at the drop, down to the meter pan, SE cables, panel and grounding need to be upgraded.
The drop from the street is typically the POCOs property. |
I am a newcomer to Canada, I know how to do it but I don't know if I'm allowed to do it with my license, because there is also construction electrician
Then whats the difference between construction electrician and electrical electrician?
Maybe Canada has different rules/titles for who can do what type of work. |
So Industrial electrician can do whatever electrical electrician?
Let's wait for a reply from someone who knows Canadian codes.
Okay, sure well anyway thanks for your help
| All times are GMT -4. The time now is 07:15 AM. |
