Old 05-27-2011, 12:31 AM   #1
Help With Panel Problem
Hi All. I've got a problem with my panel and I'm not sure how to tackle it without running brand new line . So I was hoping to find a solution other than that here. I'd like to put an interlock kit in, but slots 2 and 4 are taken.
(For those that don't know about an interlock kit, it allows you to backfeed your panel from a portable generator via a 30 Amp breaker that would be placed in slots 2 and 4. You install a plate on the panel cover that makes it impossible for the breaker and main to be hot at the same time. Thus making it code vs. a more expensive manual transfer switch.)
Not only that, but the electrician that wired the house didn't leave much slack in the line so I can't just move every breaker down two slots. Anyone have any idea on what I might be able to do?
BuckeyeGuy is offline   Reply With Quote
Old 05-27-2011, 12:47 AM   #2
Electrical Contractor
kbsparky's Avatar
MOVE the circuits from slots 2 and 4 to someplace else. Use wire-nuts or other approved splicing methods to extend the wires so they will reach the new breaker location(s).
You MUST use slots 2&4 for the interlockkit to work properly.
-KB
Old 05-27-2011, 12:59 AM   #3
I thought about wire nuts, and haven't check, but just assumed it wasn't code to use those in the load center.
Old 05-27-2011, 01:10 AM   #4
Scared Electrician
Saturday Cowboy's Avatar
One of the more popular entries in the ULEC (Urban Ledegon Electrical Code)
It is legal to splice in a panel(looks like@#^$#^ and we can tell a professional wasn't in there)
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-27-2011, 10:49 AM   #5
joed's Avatar
If you don't want the splice in the panel install a junction beside the panel. Run your cable into that and then a new piece of NM cable into the panel.
Do not PM with questions that can be asked in a forum. I will not respond.
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 10:50 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
Main Panel / Service Upgrades gbe Electrical 12 11-07-2009 12:20 AM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
