Help with outlet controlled by switch
I know the job you asked about is most likely complete already but I thought I'd add my two cents just in case.
If you want to eliminate the switched receptacle, turn the power off to the switch first, then remove the switch, wire nut the the wires, tape the wire nuts to the wire and make sure no wire is exposed and push them back in the box, put a blank cover over the outlet box (I'd keep this outlet just in case you want to use it again) then I'd pull the receptacle out and use a test light to make sure the power is off to both the top and bottom of the receptacle, then I'd remove the receptacle and wire nut the switched wires, tape the wire nuts to the wire and make sure no wire is exposed, push them back in the box (I would not cut them just in case you want to use them again) then get a new receptacle, a good one, and install it the same way the old one came out, just reconnect the the bare ground to the green or black terminal, it is usually on the bottom of the receptacle. the white wire to the white terminal and the black to the gold terminal. If you have aluminum wiring to the receptacle, make sure you use a receptacle that is made for it, it will say on the back of the receptacle, CU/AL witch means you can use it for either copper or aluminum. If you use one for aluminum it will have all white terminals, just be sure to get the the wires under the correct terminals. If you are unsure, just pull out a few receptacles in different rooms of your house and look to see how they were wired. Again, be sure the power is off to the ones you pull out, use a test light or a table lamp, just be sure it works before you turn the power off.
