HELP!!! No Power To Light Switch And Cant Find GFI's On That Circuit! - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 04:06 PM   #31
Originally Posted by gdawg1b
. True!
Determine with a non contact voltage detector from hd
I was able to find the capped black wire from information from y'all! I started snooping and found it. When I touched it to a known hot wire the light that was the original problem came on.
gdawg1b is offline   Reply With Quote
Old 12-21-2012, 04:08 PM   #32
. True!
I have no idea why it was capped! Also no idea why the arc! House was a foreclosure so still trying to work on stuff!
Old 12-21-2012, 05:40 PM   #33
Rewards Points: 1,294
Originally Posted by gdawg1b View Post
. True!
Pen testers have their place but in this case you need to use a volt/ohm meter to test with. The pen tester you are using can pick up induced voltage and give confusing readings.
If the closet light you mentioned is the same one that quit working (as you mentioned in post three) then you need to troubleshoot that circuit out more. Hooking this circuit into another one that had a different power source could cause serious problems.
danpik is offline   Reply With Quote
Old 12-22-2012, 09:32 AM   #34
Retired Electrician
Have you reset the GFCI in the bathrooms (they may have been connected improperly so even if they trip, the bathroom lights and receptacles may still work but are now tripped)
FLICKER is offline   Reply With Quote
