HELP!!! No Power To Light Switch And Cant Find GFI's On That Circuit! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 08:42 PM   #16
Originally Posted by gdawg1b
I have checked but never hurts to check again! It's in the bathroom near the weather closet so ill check that connection too! Thanks!
Actually the water closet!
gdawg1b is offline   Reply With Quote
Old 12-20-2012, 02:07 PM   #17
Found the power...intersting place but need safety advice
Would appreciate advice on this! If I connect capped black wire to unused switch I have power to closet light in next room! Wondering, based on the burn marks across the switch, if that's a bad idea! Help?
HELP!!!   No power to light switch and cant find GFI's on that circuit!-image-3124720039.jpg
HELP!!!   No power to light switch and cant find GFI's on that circuit!-image-514254829.jpg
Thanks all!
Old 12-20-2012, 03:34 PM   #18
Rewards Points: 1,092
Originally Posted by gdawg1b View Post
If I connect capped black wire to unused switch....
Thanks all!
WHAT "unused switch"? Where is it in relation to this one? It appears that you either have two hot wires coming to this box, which is not a problem but strange, or you have one hot wire coming in, getting broken by the switch, and the hot side also goes on to another location.... or something. Clue us in on which of the three black wires are hot.
Old 12-20-2012, 06:01 PM   #19
An old Tradesmen
Rewards Points: 6,074
Moved to Electrical forum.
Old 12-20-2012, 06:07 PM   #20
dmxtothemax's Avatar
Rewards Points: 5,096
Do not use that switch !
That black stuff is carbon !
Carbon is conductive !
Replace the switch.
It was probably disconnectted because
of the burnt out switch.
If the wires are damaged, cut them back.
dmxtothemax is offline   Reply With Quote
Old 12-20-2012, 06:10 PM   #21
Rewards Points: 150
... Wondering, based on the burn marks across the switch, if that's a bad idea! Help?...
Burn marks in something electrical are always a bad sign.
Dave632 is offline   Reply With Quote
Old 12-20-2012, 06:42 PM   #22
Licensed electrician
Rewards Points: 1,010
It looks like a hot wire grounded out on the metal strap of the grounded switch.
Never work on energized equipment.
Old 12-20-2012, 06:52 PM   #23
TTW
TTW's Avatar
gdaw,
You started a brand new thread on a continuing issue.
No-one will have any idea what you are talking about now.
Go back and put your first post here at the end of that GFCI thread you started, or you will have to start all over again what this is all about!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-20-2012, 09:35 PM   #24
Originally Posted by TTW
gdaw,
I'll try! iPad makes that a challenge! Good idea!
Old 12-20-2012, 09:40 PM   #25
Both of the black wires that are connected to the switch itself are hot regardless of the toggle position! The capped black wire, when uncapped and touching the upper empty screws, becomes live and powers the other closet. Strange for sure but that's why I am on here to ask those more knowledgeable!
I will change the switch for sure as someone suggested! Knew the black "burnt" looking area was not good! Thanks for verifying that!
Old 12-20-2012, 09:41 PM   #26
Replace the switch.
Thanks! That makes sense.
Once I change out that switch, am I okay to hook in all 3 black wires?
Old 12-21-2012, 05:19 AM   #27
An old Tradesmen
Threads merged.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
gdawg1b (12-21-2012), TTW (12-21-2012)
Old 12-21-2012, 05:47 AM   #28
TTW
TTW's Avatar
Does this help?
Old 12-21-2012, 06:54 AM   #29
Rewards Points: 1,294
How are you determining this?
Why is that wire unhooked and capped. Sounds like something was messed with and we are not getting the whole story
That would be a good idea as anything that is burned like that is not safe. You still need to figure out where that arc came from though
danpik is offline   Reply With Quote
Old 12-21-2012, 05:01 PM   #30
With a non contact voltage detector from Home Depot!
No idea! From the help given here I was snooping in the nearby switch boxes and saw it. Touched it to the known hot wires and the light came on!
. True!
