HELP!!! No Power To Light Switch And Cant Find GFI's On That Circuit! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 09:12 PM   #1
HELP!!! No power to light switch and cant find GFI's on that circuit!
Be kind folks I'm a newby here! I have a light in the master closet that doesn't work! I replaced the bulb, and light fixture and still nothing! I figured I'd back track and check the switch- no power there? I don't get it! How can it go out like that? I bought a switch to replace the current one but it doesn't mane sense to me to change it if there is no power to it! Any suggestions?
gdawg1b is offline   Reply With Quote
Old 12-13-2012, 09:33 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
Did it ever work?
How are you testing for power?
Can you trace the wire back to it's source?
Old 12-16-2012, 08:57 AM   #3
Originally Posted by jbfan
Did it ever work?
Yes it worked for a while then just randomly stopped. I checked for power with a circuit alert non contact voltage tester. Dead as a door nail in the whole box.
Here is the box with wires.
HELP!!!   No power to light switch and cant find GFI's on that circuit!-image-240579931.jpg
I have not been able to trace the line back to the source at this point. I am concerned bc I don't even know what's all on (or not on) that line.
Thanks for any suggestions!
Old 12-16-2012, 09:03 AM   #4
Did it ever work?
Yes it worked but randomly stopped.
I used a non contact voltage tester to look for power. (Also used on a working circuit to make sure tester worked)
I have not traced it back to the source. Not sure where to begin? Attic?
Attaching pic of switch box. Not sure if needed but....
HELP!!!   No power to light switch and cant find GFI's on that circuit!-image-1775154369.jpg
Old 12-16-2012, 11:02 AM   #5
Rewards Points: 115
did you check for a tripped breaker? anything else not working?
pokey is offline   Reply With Quote
Old 12-16-2012, 11:07 AM   #6
No tripped breaker or GFI's and everything else working. Where do I go from here? Fuse in breaker box? Junction box somewhere? Change out the switch? Frustrating!
Old 12-16-2012, 11:32 AM   #7
Rewards Points: 2,516
check the neutrals...make sure contact being made under that wire nut
hammerlane is offline   Reply With Quote
Old 12-16-2012, 11:46 AM   #8
Will do! Can I assume since closet is in the bathroom that they are on same breaker? I'll be okay killing power to that and double checking with voltage meter again?
Old 12-16-2012, 12:02 PM   #9
No you can't assume anything. First wiggle the neutrals and see if light comes on...if light comes on undo wire nut and resecure neutrals together.
Old 12-16-2012, 12:06 PM   #10
Okay. Leave power on while doing this?
Old 12-16-2012, 12:10 PM   #11
How else would you know if the light is working
The Following User Says Thank You to hammerlane For This Useful Post:
TTW (12-17-2012)
Old 12-16-2012, 12:29 PM   #12
Old 12-16-2012, 12:50 PM   #13
Whatever! You just said don't assume anything!
Thanks for the help!
Old 12-17-2012, 04:02 AM   #14
dmxtothemax's Avatar
Rewards Points: 5,496
usually the power will come from a near by light or recepticule !
Have you checked the surrounding area ?
sounds like you have a loose connection somewhere !
dmxtothemax is offline   Reply With Quote
Old 12-17-2012, 07:41 PM   #15
I have checked but never hurts to check again! It's in the bathroom near the weather closet so ill check that connection too! Thanks!
