-   -   HELP!!! No power to light switch and cant find GFI's on that circuit! (http://www.diychatroom.com/f18/help-no-power-light-switch-cant-find-gfis-circuit-166414/)
gdawg1b 12-13-2012 10:12 PM
Be kind folks I'm a newby here! I have a light in the master closet that doesn't work! I replaced the bulb, and light fixture and still nothing! I figured I'd back track and check the switch- no power there? I don't get it! How can it go out like that? I bought a switch to replace the current one but it doesn't mane sense to me to change it if there is no power to it! Any suggestions?
jbfan 12-13-2012 10:33 PM
Did it ever work?
How are you testing for power?
Can you trace the wire back to it's source?
gdawg1b 12-16-2012 09:57 AM
1 Attachment(s)
Originally Posted by jbfan
Did it ever work?
Yes it worked for a while then just randomly stopped. I checked for power with a circuit alert non contact voltage tester. Dead as a door nail in the whole box.
Here is the box with wires.
Attachment 62082
I have not been able to trace the line back to the source at this point. I am concerned bc I don't even know what's all on (or not on) that line.
Thanks for any suggestions!
gdawg1b 12-16-2012 10:03 AM
1 Attachment(s)
Did it ever work?
Yes it worked but randomly stopped.
I used a non contact voltage tester to look for power. (Also used on a working circuit to make sure tester worked)
I have not traced it back to the source. Not sure where to begin? Attic?
Attaching pic of switch box. Not sure if needed but....
Attachment 62083
pokey 12-16-2012 12:02 PM
did you check for a tripped breaker? anything else not working?
gdawg1b 12-16-2012 12:07 PM
No tripped breaker or GFI's and everything else working. Where do I go from here? Fuse in breaker box? Junction box somewhere? Change out the switch? Frustrating! :)
hammerlane 12-16-2012 12:32 PM
1 Attachment(s)
check the neutrals...make sure contact being made under that wire nut
gdawg1b 12-16-2012 12:46 PM
Will do! Can I assume since closet is in the bathroom that they are on same breaker? I'll be okay killing power to that and double checking with voltage meter again?
hammerlane 12-16-2012 01:02 PM
No you can't assume anything. First wiggle the neutrals and see if light comes on...if light comes on undo wire nut and resecure neutrals together.
gdawg1b 12-16-2012 01:06 PM
Okay. Leave power on while doing this?
hammerlane 12-16-2012 01:10 PM
How else would you know if the light is working
gdawg1b 12-16-2012 01:29 PM
gdawg1b 12-16-2012 01:50 PM
Whatever! You just said don't assume anything!
Thanks for the help!
dmxtothemax 12-17-2012 05:02 AM
usually the power will come from a near by light or recepticule !
Have you checked the surrounding area ?
sounds like you have a loose connection somewhere !
gdawg1b 12-17-2012 08:41 PM
I have checked but never hurts to check again! It's in the bathroom near the weather closet so ill check that connection too! Thanks!
