Old 03-24-2011, 05:11 PM   #1
Help! No power to light
I've been trying to hang & hard wire a chandelier in my new nursery. I hung it, Power worked fine, but it was too low. so I shortened it, re-hung and wired, and now, there is no power going to the light box, and the current to the dimmer switch is very weak. I don't quite know where to start. Any help would be great!
Bobbydigital is offline   Reply With Quote
Old 03-24-2011, 05:23 PM   #2
Super Moderator
First of all,Did you do this 'live'?-----It's easy to fry a dimmer switch if you shorted out the wires,while working.
First --test power to dimmer---then power out of dimmer---If that's good---check your wire nuts at the light fixture.----Mike----
Old 03-24-2011, 05:26 PM   #3
Super Moderator
Another thought---CFLs (curly florescent lights) will not work on most dimmers---use a regular bulb for testing.
Old 03-25-2011, 06:57 AM   #4
But Bobby said that it worked the first time so the problem must be something else than CFLs.
lark is offline   Reply With Quote
Old 03-25-2011, 07:16 AM   #5
Super Moderator
Excellent point!
Old 03-25-2011, 10:16 AM   #6
In my experience in IT, people will often change multiple things and only remember one so it's worth it to go over the list of possible issues again.
operagost is offline   Reply With Quote
Old 03-25-2011, 11:24 AM   #7
the Musigician
DangerMouse's Avatar
You can say that again..... I assisted a lady for over an hour on the phone trying to explain to her how to get her printer to work. I finally ended up going there and clicking one thing to fix it.... 30 seconds... made $30 bucks....
I wish I could do that 40 hours a week.... *grin*
We had no light in the bathroom this morning. All other lights on that circuit fine... tested fixture after testing bulb, not either of those.... opened switch, tested that, bingo. The wife will bring more switches home tonight. Po)
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 03-26-2011, 08:48 AM   #8
Dimmer switches are easy to fry, since you have partial voltage, that would be my first guess. Check the voltage coming INTO the switch, if it is not 120V the check the voltage coming out of the breaker. I imagine thats as far as you will need to go.
screwy is offline   Reply With Quote
Basic light wiring question speedster1 Electrical 3 11-29-2010 07:48 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
delayed power to light Osh Electrical 15 04-21-2010 10:30 PM
Extend a circuit/draw power from light Ontario Electrical 3 03-23-2010 07:41 PM
no power to light switch diople Electrical 6 05-16-2009 02:40 PM
