HELP! Newly Installed METAL Junction Box Becomes LIVE!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 06:55 PM   #1
HELP! Newly Installed METAL Junction Box becomes LIVE!!!
So I recently installed a NEW Metal Junction box (looks like this: http://www.homedepot.com/Electrical-...&storeId=10051) and I nailed it to a wooden stud in my basement. I use the yellow 12/2 Romex wire with ground. Coming in the box from the top is from the power source (A previous GFCI in the circuit) and I wire nutted the GROUND, HOT, and NEUTRAL securely to the complementary wires leaving the metal junction box to the new GFCI outlet. So everything is organized and there are no cuts or slits in the NEW Romex wire... BUT when I go back to the Breaker Panel, And I turn the power on, I use my NON-CONTACT VOLTAGE TESTER and test for any dangers.
The new GFCI works. HOWEVER,
my voltage tester beeps when I put it next to the METAL box. So I did not touch the box cause I was scared that it was LIVE.... I really don't know why it is live! So how can I find out if this new Metal Box is really LIVE and dangerous and not the voltage tester's error? (Obviously without touching the box directly with my fingers) THANKS!
Would replacing the junction box with a PLASTIC box work?
bingbong26 is offline   Reply With Quote
Old 06-25-2012, 07:07 PM   #2
Rewards Points: 13,724
Just use a real volt ohm meter between the white and the box and see what happens.
Most likly your just picking up a false signal.
I almost never use steel boxes anymore. Cost more, and with plastic there's less chance of a short.
Old 06-25-2012, 07:12 PM   #3
Missouri Bound's Avatar
Non-contact testers let you know if there is power in the vicinity of the wiring....no more, no less. You need a real tester as well. I'm not knocking non-contact testers...they have a purpose in signaling the alarm that a live circuit is present.
Do you want it your way or the right way?
Old 06-25-2012, 08:21 PM   #4
Rewards Points: 330
you also need to ground metal boxes.there is a hole to accept a 10-32 ground screw.pigtail and attach ground wire to box.did not see where you did that.
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
mpoulton (06-26-2012)
Old 06-26-2012, 03:30 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,938
While the non-contact tester may be giving a false reading, it should not be doing so when near a grounded metal box. Make sure the box is grounded - your description did not mention that. Also, you do not need a GFCI receptacle if it is being fed from another GFCI receptacle. Just feed it from the load side and it will be protected.
mpoulton is online now   Reply With Quote
Old 06-26-2012, 05:22 AM   #6
Electrical Contractor
kbsparky's Avatar
A beep tester can show a false positive when the grounding conductor is broken, and induction picks it up.
A real tester is needed here to determine the actual problems ...
-KB
Garage feeder junction box bonding WillK Electrical 0 06-05-2011 10:03 AM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 05:54 AM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 10:00 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
