Help: New Construction And No Outlet/electrical Boxes.. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 10:39 PM   #1
Help: New Construction and no outlet/electrical boxes..
About a year after we bought our house we decided to change all the light fixtures (except ceiling fan in Master BR and LR). When we went to install our first set in the Master Bath there was no electrical box behind the current fixture...just wires coming from a hole in the wall...
As we went through the house this turned out to be the case for every ceiling flushmount or wall light fixture.
Isn't this against code? (we live in GA) We added round electrical boxes to the bathroom wall fixtures. Should we do this for every ceiling flushmount in the halls, foyers closets as well?
Will I ever be able to sell this house like this?
braselton is offline   Reply With Quote
Old 06-10-2009, 10:52 PM   #2
Rewards Points: 2,350
Ah, Braselton... Been a while since I was there. But yes, it is against code unless the fixture is designed to be direct wired to a cable.
Old 06-11-2009, 06:12 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Yep. Not to code. I might be calling the inspection deparment to find out who and why this passed.
Old 06-11-2009, 08:05 AM   #4
Registered User
Termite's Avatar
I'll second that! Reasonably easy problem to fix, but shameful that the inspector didn't catch it.
Old 06-11-2009, 08:17 AM   #5
Tell you the truth, I don't think the City of Braselton has an inspection department, and Jackson County may not have had one until just a few years ago.
Old 06-11-2009, 09:03 AM   #6
Licensed Pro
Braselton, GA... formerly owned by Kim Basinger... now that's a real topic for discussion!
Old 06-11-2009, 10:23 AM   #7
Rewards Points: 346
If, as your subject line says this was "new" construction and you are the original buyer it should be a simple matter to get this corrected. Unless you had a very non-standard contract to build this home it will indicate the home will meet a some specification. Your problem is just one of the reasons getting a new home inspected is money well spent unless you are very familiar with home construction. Even if you are familiar with construction it will make the walk through a breeze if you have the inspection results from a reputable home inspection company.
How did I learn this lesson, not from the home builder... but please don't ask.
Rege
RegeSullivan is offline   Reply With Quote
Old 06-11-2009, 11:05 AM   #8
That's bad, do you know who built the house?
Was this a new house?
Rehabbed?
Old 06-11-2009, 11:30 AM   #9
New construction
Not to code
...who inspected it?
...who passed it?
...are you the original owner?
You need a proper house/electrical inspection to discover all the other violations and safety hazards you have (like that fixture in the "closet" - what kind of fixture?)
Then you might need a lawyer.
Willis
williswires is offline   Reply With Quote
Old 06-11-2009, 11:41 AM   #10
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
What type of wire was used? If it was romex you're in luck because installing boxes is easier with romex than it is with armored cable.
If the last "electrician" didn't bother to install boxes, you're likely to have some grounding and bonding issues within the electrical system itself too.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
replacing box in wall with new construction type DIYGST Electrical 15 02-23-2009 11:05 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing/Siding 21 03-26-2008 11:05 PM
New Job in construction Punk8oy81 Carpentry 4 01-28-2007 06:15 PM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 03:57 PM
