Help New Addition Electrical Sub Panel/Load - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 11:13 PM   #16
Rewards Points: 164
Mines only 60 amp
ryan50hrl is offline   Reply With Quote
Old 07-29-2012, 11:15 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by ryan50hrl View Post
Mines only 60 amp
What exactly was your question?
Old 07-29-2012, 11:16 PM   #18
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Mines only 60 amp
Sorry...I thought you were the OP.
Old 07-30-2012, 02:28 AM   #19
Did I notice that you were leaving the fridge in the old panel?
If you're moving the whole kitchen I would think you'd be pulling out more than just the 40a stove breaker from the old panel? Unless everything was jumbled together in there to begin with.
Evstarr is offline   Reply With Quote
Old 07-30-2012, 08:34 AM   #20
The current set up has all the kitchen receptacles on one circuit and a 40 amp for the range. I am adding the cook top, base board heat, dedicated microwave circuit and dishwasher. Those will be the new Appliances that will draw additional electricity.
RISurfer is offline   Reply With Quote
Electrical codes from 1970's -- Old work frustrations... PirateKatz Electrical 3 03-18-2009 07:35 PM
Footing/Foundation for Addition stubits Building & Construction 1 03-11-2009 02:43 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
to add an addition or not..... elmorem@gmail.com Building & Construction 2 02-17-2008 11:43 PM
