Help Needed With Wireing Of Halloween Project - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2007, 10:18 PM   #1
help needed with wireing of halloween project
I have a Halloween projectů Im trying to make a project using both 12v and 110. I have a washing machine solenoid (110) hooked up to an air compressor. I also have a 12v light system that I have powered by a landscaping electrical transformer. Im trying to see what type of switch I can use (DPDT?) to turn them both on at the same time, and how I would wire this. Any Ideas?
djpuf is offline   Reply With Quote
Old 10-29-2007, 11:07 PM   #2
sure, buy a dpdt wall switch from your local supply house.
Master Electrician
jwhite is offline   Reply With Quote
Old 10-29-2007, 11:09 PM   #3
oh and you want to know how to wire the thing.....
we need a soo... Sequence of opperation. in order to figure out the wiring.
so how do you want it to work?
Master Electrician
Old 10-30-2007, 09:06 AM   #4
im trying to get the solenoid (110v) and the lights (12v) to fire at the same time. I guess I'll have to run 110 to the switch, split after the switch to go to the solenoid and to the transformer. The only thing is I'm not sure how to wire the switch. Give me a switch or outlet to replace in my house and im fine. Make me wire it myself and im lost....
Old 10-30-2007, 08:40 PM   #5
Remodeler
MinConst's Avatar
Switch the hot side of the feed. Black wire into switch, black wire out of switch. White stays connected and so does the ground. You will end up with 3 wires going to the switch box, three wires coming out of the switch box. Black wire is switched. Run these to your decorations, slit them in another junction box and you will have two sets. Make sure this is all in water outdoor boxes if this stuff is outside.
If your not comfortable doing ANY of this DON'T! There will probably be children involved.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
My Custom In-Wall Entertainment Center Project! With lots of photos!! joseph011 Project Showcase 12 01-03-2011 02:43 PM
how to bid out my project Sommers General DIY Discussions 12 10-11-2007 02:50 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
