Old 03-24-2008, 10:11 AM   #1
Help needed on wire termination
I had a hard wire for an exhaust hood that I relocated to another section of the kitchen (the exhaust hood). I therefore had an unused wire... what is the best way to terminate this wire? I originally capped the wire by placing wire nuts on the bare wires and leaving in the wall. What should I go back and do?
Any help would be appreciated.
Phineas
Phineas is offline   Reply With Quote
Old 03-24-2008, 10:18 AM   #2
When is fishing season?
CowboyAndy's Avatar
Is the wire still live?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-24-2008, 11:22 AM   #3
I sold the house to another owner, got more savvy about electrical stuff and realized this could be a huge problem, so I would assume the wire is still live.
Wanted to make this right for the new owner...
Old 03-24-2008, 11:33 AM   #4
J. V.'s Avatar
You need to open up the wall, install a box and bring the wire into the box. Then cut off the ends so no wire is showing, then install the wire nuts. You must leave this box accessible.
Or, if you can find where the cable originates, you can disconnect it there and forget about the cable behind the wall.
If it were me I would contact the new owner and tell him what is going on and let him decide what he wants to do.
Old 03-24-2008, 11:41 AM   #5
Pretty much what I was thinking...thanks for your input.
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 10:11 AM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 09:23 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 01:20 PM
