Help Needed W/Kitchen Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 01:27 PM   #1
Help Needed w/Kitchen Wiring
I am installing recessed "can" lighting in my kitchen as part of a complete make0over. The kitchen is fully exposed (no drywall) so wiring is not a chore. Is the sketch I've drawn correct to wire 7 lights from 3 different switches (NOT 3-Way) using the same feed?
Thank you for your help!
-Chuck
planewood1 is offline   Reply With Quote
Old 10-24-2011, 02:31 PM   #2
Electrical Contractor
jbfan's Avatar
Electrically the circuit works.
Are all the switches located in the same box?
jbfan is online now   Reply With Quote
Old 10-24-2011, 02:51 PM   #3
Yes, they are. They will potentially be dimmers, but I defer to the wife on that.
Also, there is an existing switch that will be in the same box (4-Gang when completed) on a different circuit that will light an existing over-head fixture.
I ran 12/2 on a 20 amp circuit for these cans, because the Mrs. is not sure if she wants the LED's or incandescent. Probably over-kill, but every circuit, whether lighting or appliance, is 20 amp (the house was this way when we bought). I have yet to wire in the breaker, so if one tells me that is not good, I will use a 15 amp.
Thank you for your help. I appreciate it immensely!
-Chuck
Old 10-24-2011, 03:09 PM   #4
Code05's Avatar
Rewards Points: 1,104
12/2 on a 20 amp breaker is fine.
Code05 is offline   Reply With Quote
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 07:52 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Wiring Help Needed aced19 Electrical 17 03-30-2009 10:30 AM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 02:42 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
